Question about Garmin nuvi GPS
Lg g4 will not pare with Bluetooth garmin nuvi gps?
Phone will not pare with my nuvi gps. Can you help?
Posted by Jerry Hazard on
5 Related Answers
Anonymous
  • 77 Answers
SOURCE: Garmin Nuvi 7700 bluetooth to LG enV-VX9900
You don't. This phone is incapible of that as it's a VZ nav. capible phone. Sorry.
Posted on Dec 31, 2007
TO Lady
  • 638 Answers
SOURCE: Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Posted on Jan 08, 2009
Anonymous
SOURCE: My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
Posted on Oct 10, 2009
Anonymous
  • 160 Answers
SOURCE: locked out of Garmin nuvi
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. If you would like to back up your favorites you can find instructions to do so here.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
riceski
Gary Rice
  • 1851 Answers
SOURCE: nuviĀ® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
Posted on May 21, 2010
I have a Garmin nuvi 1490 and I just bought a Verizon Samsung SW/HW VERISON but cannot connect my Bluetooth phone? Help Ron
i have conected my bluetooth to my satnav when it comes up yes i prees yes how do i get my menu up from my phone to my satnav
2answers
No contacts on GPS from Nokia E71
You may have to allow access from your bluetooth to your phone via your buetooth menu on you garmin. I know I did that with my mortorla phone and garmin. I hope this helps. If not I will try to get mine to work. I use a motorola blue tooth car speaker it has better noise canceling and reception.
I wish to erase phone numbers, transferred from my cell phone to my Garmin 265WT when pairing the phone to the Garmin. These phone numbers came from my cell phone and I cannot remember who is associated...
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
How do i pair my 265wt with my LG vx9900?
Garmin claims the nuvi 265wt (et al) supports the LG VX9400, which means it's also likely to support the VX990 (but one can't be certain).
1. From the main screen on the nuvi, touch Tools>Settings>Bluetooth.
2. Select Enabled.
3. On the VX9900, do the equivalent to enable its Bluetooth port.
4. Let your phone search for Bluetooth devices.
5. Select the nuvi from the list.
6. Enter the nuvi Bluetooth PIN (1234) into your phone.
You can do steps 4-6 from the nuvi if your phone is already enabled for Bluetooth.
I have a garmin nuvi 265w and when i connect via bluetooth to my BBerry curve the garmin turns off and on occasionally (usually at a critical point in my trip or during a phone call !). i have the current...
Also, a Nuvi that is turning off and on is symptomatic of having corrupt firmware.
I hope that helps.
Microphone not picking up any sound in bluetooth mode.
Hi Joe,
First, I would go to the Garmin website and update the bluetooth software. Garmin just released v3.4 a few days ago (November of 2008). Use their webupdater to upgrade the BT firmware.
When you update the firmware, it will erase your phone paring data and you will have to re-pair the phone with your Nuvi.
Now, if that doesn't fix your microphone issue, you have either one of the following two problems:
1. The microphone is a condenser microphone. It's about a 1/4" in diameter and sits behind the front slot located in the lower left hand corner. The microphone has two wires (red & black) that run from the microphone to the main board. At the end of the wires is a 2 position plug that plugs into the main board. This plug can come loose as there is no lock mechanism on it.
2. The microphone is defective.
Please do not try to take apart your Nuvi unless you have the right tools. I have received many emails from people who have further damaged their Nuvi, trying to get it open.
Please let me know if you need further help with this problem.
Good Luck,
- Jim
Dont have cell phone icon anymore on nuvi 360
Have you tried to re-pair it with your phone? What does the bluetooth firmware version show up as on your Nuvi? If it says 0.0, you need to reflash the bluetooth firmware. You can find the firmware version by selecting the wrench icon, then sekect the gear symbol and then select "About". Use Garmin's webupdater and connect your Nuvi to the PC and let the webupdater reflash yoour Nuvi. Garmin just updated the bluetooth firmware on November of 08 to v3.4 so you would want to do it anyway. When you reflash, you have to repair the phone to the Nuvi because the reflash erases your phone setup.
- Jim
Need Info
Read the manual and you will be able to connect Bluetooth TO 660 , menu Bluetooth active , be sure you LG phone is active on his bluetooth, connect and recognize will be done , you will see.
GARMIN 660 is working with a battery and also with your car adapter. I don't see any reason why it would not work on battery ?.
Your issue is not clear concerning the battery ?
best regards
2answers
Need Info
Well your are on 660 review forum sir not 760.
Easy contact GARMIN and ask for the list of recommended cell phone who work with it. Normally most of them are working fine and the connection BLUETOOTH is recognize
3answers
My Garmin 680 bluetooth stopped working w/ my LG Vx8600
I have found the only thing that works thus far is to click on the red phone in progress icon then go to "call options" then click transfer audio to phone, then transfer audio to nuvi. Sometimes I have to do this twice. but it works.
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
