Question about Casio Office Equipment & Supplies
The thousand separator is not displaying in my casio MS-80VER calculator
Posted by James Burke on
5 Related Answers
Anonymous
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Posted on Apr 12, 2007
1badengineer
SOURCE: Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Posted on Jan 11, 2008
Anonymous
SOURCE: how do I change the
How do I program tax rate into my calculator? Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Dec 10, 2008
Anonymous
SOURCE: how to change tax rate on MS-8TV calculator
Press AC first, then hold down the RATE SET % button for 2 seconds, then input the rate and press RATE SET % button again
And you should be away :-)
Posted on Jan 07, 2010
Anonymous
SOURCE: Need to change tax rate
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
Posted on Dec 09, 2010
I want to bring comma as seperator between thousands
This calculator does not have a separator for thousands, millions, etc. This feature may have seemed to the designers to be unimportant in a scientific calculator.
You can however change the decimal mark from the dot to the comma. To do that, press [SHIFT][Mode] to enter (Setup).
Press the Arrow down. In new screen look for 5:Disp.
Nov 10, 2013 | Casio FX-115ES Scientific Calculator
I have just changed from using a Casio fx-83MS to a fx-83GT Plus. Is there a way of displaying a comma between every third whole number?
I do not think that Casio scientific calculators have the possibility to separate thousands, millions etc. The Sharp have that feature.
Sep 15, 2013 | Casio Office Equipment & Supplies
Display comma placeholder
The Casio Fx300ES does not provide comma or other separation/ spacing symbol to separate thousands.
Sep 26, 2012 | Casio fx-300ES Calculator
I want thousand seperator in my answer in casi sceintific calculator fx570es plus
Sorry, the fx-570ES Plus does not have the ability to insert thousands separators into numbers.
May 11, 2012 | Casio FX-115ES Scientific Calculator
Fx-570 ES how can i get comma is the results for example 100,000,000. Comma after every three digits?
Sorry but you cannot. You can change the decimal mark from dot to comma but you cannot have the calculator separate the digits between thousands (thousands separator).
Jan 24, 2012 | Casio FX570ES Scientific Calculator
My calculator casio fx 350ES doesnt give me right anwser.this is the anwser from my calculator when i inter this numbers 220 000-100 000=120 (there should be 3 more zeros).it happens all the time when i...
Did you enter a dot as a separator for the thousands? If yes, this is the error. The calculator interprets all digits following the dot as fractions of decimals.
So you enter 220.000 meaning 220 thousand, your calculator gets it as 220 comma 0, and thats where your three zeros go...
To make it right, enter your numbers as 220000 - 100000 and you'll get 120000 as result.
Jan 10, 2011 | Casio FX-115ES Scientific Calculator
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Aug 19, 2010 | Casio MS-80TE Calculator
88 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
