Question about Lexar Electronics - Others
How to remove write protected in Lexar 4GB - Lexar Electronics - Others
Posted by Ivo Gatchalian on
Clive
  • Lexar Master
  • 882 Answers
You may need Administrator privileges on your computer.
Plug in flash-drive.
Allow time for Windows Explorer to read it.
Run AV scan if suspect.
To get a list of attributes:
Launch Start > Run > CMD.
From the command console enter
attrib F:
(or whatever the drive letter is for your flash).
to redirect output to a text file enter (example)
attrib f:>%homepath%\flashatb.txt
From the list you should see [H]idden, [S]ystem or [R]ead only attributes for write-protected files.
You can also do it via Win Explorer by right-clicking the drive icon.
Remove all above attributes.
As a last resort, you can full-format the entire flash via explorer.
Which should wipe all files / folders on the drive.
Posted on Jul 05, 2018
SD card says write protected
There is a small tab on the card that you can move to change this.
Oct 04, 2015 | Lexar Micro Sd Sdhc 4gb Class 2 Flash...
Lexar memory stick 4Gb
Maybe your stick was not formatted at all.it can be possible that the area of memory that is not visible is occupied by a virus.i once faced that prob but i used KASPERSKY INTERNET SECURITY.Its one of the best try scanning the stick that is if you havent tried it yet.Hope it works
Mar 22, 2014 | Computers & Internet
LEXAR MULTI-USE 16GB SDHC - CANNOT REMOVE WRITE PROTECTION
you can remove the right protection from the computer you use to create the right protection, if you want to use diferend computer that's impossible but same you can go to start and type CMD the comand prompt once the (CMD) folder will open, type (discpart) another (CMD) folder will open type list disc that is going to highlight all the disc on your computer or laptop, now type select disc and exact number of the flash drive if it's 1 2 or3 and hit enter it will select exact number with the flash drive, now attribute clear readonly and enter, now it will says attribute successfully, now type exit to see changes remove the flash drive and plug it back done
Feb 28, 2018 | Electronics - Others
Format 4gb lexar jumptwist
The thumb drive you have came already formatted and ready to use. It will read as a DISK because it works the same as a CD or DVD disc. A formatted flash drive is set up at the factory and ready to be used by the new owner. Just copy what you want to move from the computer to the flash drive. When you want to remove data from the flash drive, simply DELETE doing the same as you would on your computer PC or Laptop.
Dec 19, 2013 | Lexar 8GB JumpDrive TwistTurn - USB Flash...
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
My sony cyber shot camera suddenly is saying that my Lexar 4GB CompactFlash Premium Series 80x needs to be formatted. What about my pictures?
You might have locked memory card. If not first try to connect memory card to PC with memory card reader and try to copy your stuff... then after you take all stuff try to format it.
Sep 16, 2012 | Lexar 4GB Professional Series 80x...
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
Jul 11, 2010 | Lexar JumpDrive Classic Portable USB Data...
My lexar 4gb sdhc keeps telling me its locked how can i unlock it
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 06, 2010 | Sanyo Cameras
I have a windows xp and a lexar microsd 4gb adapter
Hi If your card is SDHC version is possible that you card adapter doesn't support it, you have to try another one.
Oct 19, 2009 | SanDisk 2GB microSD Memory Card
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Electronics - Others Logo
339 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
