Question about Casio Office Equipment & Supplies
My Casio label printerXL-60 is giving me an error message....INT? Can you help me?
Posted by Anna Osbeck on
5 Related Answers
Anonymous
SOURCE: I have a casio kl-60
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_60_E.pdf
Posted on Aug 30, 2008
Anonymous
SOURCE: casio camera lens stuck
i droped my camra and now the lense is like stuck where can i go to get it fixed
Posted on Jul 27, 2008
Anonymous
SOURCE: Casio KL7200 label maker Message:
Press any key other than "on/off" to clear the DATA ERROR off the screen. Then, the screen will say "initial". Press "set"
Posted on Jan 12, 2009
A Soveral
  • 566 Answers
SOURCE: I have a kl-60-l label maker.
Here is the link to CASIO KL-60 Manual
Check the troubleshooting section in the end, and also the "Resetting the Memory" section.
Posted on Aug 09, 2009
Anonymous
SOURCE: Replaced batteries on my Casio EZ Label printer
When you get the ERR! message press set. Then you will get the INT? message. Hit set again.
Posted on Sep 21, 2010
Shows ERR when turned on
Hi, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Mac =)
Dec 28, 2013 | Casio KL-60 label maker
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Hope this helps.
Best wishes
Mac =)
When I turn the casio ez label printer on, it say's "ERR!". Then if I push escape, it says "INT?". If I type in any letters and then try to print, it says "ERR!" It...
Take out the tape and spin the drive for the tape. Put it back together and it should work. I hope this provides some assistance to you.
May 27, 2011 | Casio EZ Label Printer
How to find general anti-derivative Problems in Casio fx-115ES... I get the message syntax error, and also when the anti-derivative is bounded I get my answers in decimal form, i dont want decimal form......
I assume that by anti-derivative you mean the integral. I believe that you can only calculate definite integrals with this calculator. A definite integral requires that you specify the function e.g ln(x), the variable, x, the numerical value of the lower limit, 0.5 and the numerical value of the upper limit , say 2.
Try this: INT(sin(x),x, 0, pi/2)
This calculator can only give numerical values of definite integrals. If you want to perform symbolic calculations, you shoul look towards some other, more sophisticated Casios Casio ClassPad 330, or the TI Voyage200PLT, or the TI89Titanium. etc.
Hope it helps
Aug 28, 2009 | Casio FX-115ES Scientific Calculator
Aug 09, 2009 | Casio EZ Label Printer
I can't find how to input Int on my calculator
Hi. Many of the fx 9750's functions are hidden; they are accessed via the 6 grey F keys under the display. To use Int, Frac, Abs functions, after you turn on your calculator, in normal mode (menu 1 selection), press [OPTN] [F6] [ F4]
This will give you the number menu, containing Abs, Int, Frac, Rnd and Intg
Int is the F2 key. Press [F2] first, then enter number or variable. Int value will be shown.
Hope this helps.
Mar 11, 2009 | Casio FX-9750GPlus Calculator
Error
turn off your printer press PRINT & ESC at the same time, prees on/off at same time then release the PRINT & ESC botton then press SET
Apr 27, 2008 | Casio KL60SR Label Printer
972 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
