Was given an old 52500 Honeywell 52500 air purifier. Bought new HEPA filter & pre-filter. The purifier worked for 3 days. The next day it would not turn on at all, even with plugging into different outlets. Have tried reseating the filters, and it still does not come on. Any ideas, other than returning the new filters & throwing it out?
SOURCE: Honeywell Air Purifier model 18155 simply won't turn on
Check the manufacturer's instructions here for resetting of sensors and filter maintenance:
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=9e95591e04f403455b17cb06b484568d
Posted on Jan 03, 2008
SOURCE: how to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Posted on Apr 27, 2008
SOURCE: Kenmore Progressive 335
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
Posted on Dec 25, 2014
SOURCE: I had a honeywell hepa
do you have the wiring diagram for this ? there are two wires comin gout of this sensor circuit board. Black and white. do you knwo where they get connected? thank you
Posted on Jun 14, 2016
SOURCE: Why HEPA certified Filters are more preferred?
you can refer to this source for best answer
http://buypuritii.com/
Posted on Dec 09, 2016
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
