Question about Creative Labs Live! Cam Voice Webcam
FIXED YELLOW LINE DURING SKYPE VIDEO
All of the sudden I've got a fixed yellow line down the center of my screen during SKYPE video calls....Anyone know how to fix the problem?? OS is Windows XP 2nd edition....latest version of SKYPE available...
Posted by Brian Conlan on
  • 2 more comments
  • Anonymous Mar 20, 2008
    yellow line down the middle of the picture
  • cpsimon Nov 01, 2008
    I have a yellow line down the center of receiving video. Colors in receiving video are also off. I have the latest version of Skype. I am using XP OS with all the patches. The computer has a intel dual core. The sending video is fine.
  • Anonymous Dec 29, 2008
    Ihave the same problem and it truly interferes with the visual aspect of seeing my family long distance. If anyone knows the answer to this annoying yellow stripe, please enlighten me.
    Thank you............Patricia
  • boop_in Jan 13, 2009
    Any can help with the solution. I am having the same problem
droryonit
I found this solution in http://forum.skype.com/index.php?showtopic=105497 - it worked for me.
1 - click "start" and choose the option to "run";
2 - type "dxdiag" and confirm in OK;
3 - a screen will appear with "DirectX Diagnostic Tool";
4 - chooses the "display" tab;
5 - disable the options "DirectDraw Acceleration" and "Direct3D Acceleration"
Posted on Jun 06, 2008
HTJAMES
Re solution #4. Disabled only "Direct3D Acceleration". The yellow line has gone. With both disabled the picture is pixelated.
Thanx James T.
Posted on Jun 11, 2008
Anonymous
Solution by James is more accurate. Thanks for all solutions.
Posted on Jul 12, 2008
  • Anonymous Jul 12, 2008
    James solution is more accurate. Thanks for all the solutions.
Anonymous
I have had the same as solution #6 however, sometimes it works and other times it does not!! if it does not, then i have to live with it. I went to download another driver too but it seemed to be a really big pain and now im living with it. sometimes works and others not. It also seems to be worse with the latest version of skype. I shouldn'[t have installed the newest version. I had better luck with older version but I do not know how to get it back!!!
Posted on Oct 15, 2009
  • Anonymous Oct 15, 2009
    UPDATE FOR SOLUTION #8: I FOUND THE SITE :
    http://www.oldapps.com/skype.php?old_sky...
    Uninstalled Version 4.1.0.166 and downloaded and uinstalled Version 4.0.0.226 which I originally had. I corresponded with Skype and they said the new version 4.1 would solve the problem. It did not. As i said above, it worked sometime and others it didn't. Now with 4.0.0.226 it can be fixed with lowering the acelleration like it states in Solution #6.
    Good Luck!!!!
Anonymous
    Problem Solver:
  • 9 Answers
Hi there
I have fixed the yellow stripe problem on Skype by going the the intel link, scanning on their site for driver updates and it showed an update for me which I installed and the yellow stripe has gone. Here is the link and hope it helps others.
http://downloadcenter.intel.com/default.aspx?iid=homepage+hdr_nav2_download
Posted on Sep 21, 2009
Anonymous
Solution #5 worked for me but I also had to turn it down 2 notches to make it go away. Thanks for the help everyone.
Stet
Posted on Jan 21, 2010
Anonymous
Solution No.3 solved the yellow line problem I had with skype.
Taxitomw.
Posted on Mar 23, 2009
Anonymous
I turned the hardware acceleration down as "guest" suggested, but I had to turn it down several spots. however, once I turned it back up, the video was still working normally.
Posted on Apr 08, 2008
Anonymous
This does not help. Any other ideas?
Posted on Jan 06, 2008
Anonymous
This can be fixed by right clicking on the desktop and selecting - Properties - Settings Tab - Advanced Button - Troubleshoot Tab - move hardware acceleration pointer one notch to left - OK - OK.
A:-)A
Posted on Dec 05, 2007
How do I star a video chat
you will need to install a messenger program to make video chat skype or yahoo messenger or somethin similar
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps
May 13, 2011 | Acer Computers & Internet
When I go on skype the party I am video calling shows up with a green line down the middle of the screen from top to bottom. Is this a problem on my end or the other party?
The yellow or green band is a well known issue
Check out the Skype forum for more information
http://forum.skype.com/index.php?showtopic=109251
Nov 05, 2009 | Logitech QuickCam Communicate STX Personal...
Do i have to pay a fee before i can talk to friends by video webcam??? if not how do i get on line??
You dont have to pay any fees for using your webcam in skype. Your system would have already configured your webcam with skype. So during the call there will be a video button which you have to click to start your video.
If your webcam is not detected, go to video settings and set your webcam using the dropdown listbox in video settings.
Good luck,
Jegan
Jun 12, 2009 | Skype IM
Racieveing a bad image during the video call on Skype
Send this to them so they can properly setup the Audio & Video.
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
May 04, 2009 | Samsung Pleomax PWC 3800 Webcam
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Solid yellow line on recipients screen
I lost my drive for my crative no. PD1130
Nov 24, 2007 | Creative Labs WebCam Live!
Nov 17, 2007 | Logitech Quickcam IM 961361-0403 Webcam
Right click on the desktop, go to Properties --> Settings --> Advanced --> Troubleshoot --> Drag the Hardware acceleration pointer to the left or adjust it then apply...this should solve the problem..
Nov 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Creative Labs Live! Cam Voice Webcam Logo
7,162 people viewed this question
Top Creative Labs Computers & Internet Experts
Ekse
Geoff
Muntejaya Ginting
Muntejaya Ginting
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
