Question about GE Audio Players & Recorders
I moved a GE under counter radio CD player from one house to another. The under counter light works so it is getting power.
The display does not light up. The clock, radio, CD player does not work. What happened?
Posted by Martha Loyd on
5 Related Answers
Anonymous
SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Posted on Mar 09, 2008
emissionwiz
Marvin
  • 85241 Answers
SOURCE: car radio clock
YOU NEED TO REPLACE THE MINIATURE BULB THAT LITES UP THE DISPLAY, YOU WILL HAVE TO REMOVE THE RADIO FROM THE CAR AND THEN REMOVE THE TOP SHEET METAL COVER ON THE RADIO, YOU WILL SEE THE BULB SOCKET PLUGGED INTO THE BACK OF THE DISPLAY.
Posted on Aug 21, 2008
Anonymous
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
Anonymous
SOURCE: Clock Setting
Press SET to enter time setting mode. Use the TRACK/SEARCH/TUNE buttons to select the correct time. Press SET to save clock time.
Posted on Jul 13, 2009
Anonymous
  • 10865 Answers
SOURCE: I cannot set the time on my GE Spacemaker under
push the time button then set the time then push the time button a second time.
Posted on Sep 07, 2009
1helpful
An alarm beeping goes off at midnite, dont know how to stop it. is a GE under the counter radio/cd player. dont know how to stop the midnite alarm clock beeping.
Unplug the thing from the outlet and that will surely stop it.  Grab you a hammer and apply force to the unit multiple times and that will surely stop it.  Use the kitchen sink sprayer and hose the thing down and that will surely stop it.
Here you go: http://www.fixya.com/search.aspx?_s=GE+7-5295+manuals
12helpful
2answers
Clock Setting
29helpful
4answers
Complicated GE clock radio/CD player
To set the time:
Hope this helps.
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Kardoc
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
