SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
SOURCE: the red standby light flashes and when the power
One of the boards (module) has a short on it, and or the power supply itself is failing.
The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
Jerry G.
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
