After turning car off need to jump to start but fires right up, as long as headlights arn't on. Replaced alternator, did load check on charging system. All fine
Sounds like the battery is shot, even though the charging system is operational, the battery doesn't seem to be taking a charge.
If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
SOURCE: battary light on , engine cut off car won't crank
sounds like it's your alternator, your alternator charges your battery and runs car once it is started. if you have a bad alternator your battery light will come on, and shortly after your vehicle will die, unable to restart without a jump. I would take your battery to autozone or an auto shop to have your battery and alternator tested.
SOURCE: Daughter called me ..car wont
it sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
SOURCE: 2002 Kia Sedona new battery & alternator car dies while driving
I have the same problem with my chevy aveo and I got a new battery and alternator and had both test charge it up and died again went had both battery and alternator checked again because the new alternator was only putting out 11 amps when having it checked it was good it was putting what it was supposed to they said that I may fried my computer by having to keep jump starting it you may need to have your computer looked may need a new cc fuse and for them to reprogram it if have checked your stuff wen u left and its new then more then likely its something else
