Question about LaCie Computers & Internet
How do I turn the LaCie 300722 DVD RW burner on?
Posted by Ron Cowherd on
dking333
    New Friend:
  • 36 Answers
Here is the user manual for your device:
https://www.lacie.com/files/lacie-content/manual/d2_dl_dvd_toast7_en.pdf
Posted on Feb 09, 2018
5 Related Answers
Anonymous
  • 46 Answers
SOURCE: My Ricoh Mp5120A(which isn't on the list) DVD+RW & CD+RW burner
some drives can only read plus disks and not minus as well im afraid
Posted on Sep 27, 2007
Anonymous
SOURCE: just bought a lacie d2
Disconnect the Lacie dvd drive, then reconnect it and open "system profiler" to see if the drive is now recognized under "firewire" or USB depending on your connection. If that doesn't work disconnect all peripherals and turn off your mac for 5 minutes. Start reconnecting your devices one by one.
Posted on Dec 16, 2008
Anonymous
  • 520 Answers
SOURCE: How to install a RW dvd burner
os should of recognised it and installed it..maybe it installed as generic and isnt suitable.
click start , right click my computer , click properties.....In system properties screen click hardware then device manager.
here youll find youre cd/dvd device.double click on it to open and display details/driver etc.click driver heading then update...app opens giving options choose use internet.
if it cant find software check the cd/dvd name/model ( in properties still open) write it down and search on net for it....download it install it
Posted on Jan 06, 2009
Anonymous
  • 51 Answers
SOURCE: dvd+rw burner wont reconize dvd's
The eye on the dvd+rw burner may have dust on it.
Posted on May 11, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: I have lost my power cord to my LaCie DVD+RW Dual Layer....
Here is the PDF Users Manual for the LaCie DVD+RW 301230U
external optical drive,
http://www.lacie.com/download/manual/portable_dvd_sh_en.pdf
(Give it at least 10 seconds to download)
Should the direct link above not work for you, you can download the Users Manual from here,
http://www.generalmanual.com/Disc-Burners/LaCie-301230U-Portable-DVD-RW.htm
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual
The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like,
http://en.wikipedia.org/wiki/File:USB_TypeA_Plug.JPG
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this,
http://en.wikipedia.org/wiki/File:USB_types_2.jpg
It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is LaCie.com, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive,
http://www.lacie.com/us/products/product.htm?pid=10715
Posted on May 16, 2009
I upgraded to Windows 7 & my Lacie DVD burner does not seem to work. Do I need to upgrade my software? How?
It must be a driver for the writer on the page of Lacie, anyway it should work without it,
Jan 26, 2013 | LaCie (300978) DVD RW Dual Layer Burner
Need to re-install drivers for LaCie 2d DVD RW with lightscribe
HI there,Use the page below to get your drivers, download them by saving to your desktop, and then install from the saved file.
http://www.lacie.com/search/index.htm
Regards
Sep 11, 2010 | LaCie d2 DVD-RW Burner
May 15, 2009 | LaCie (300776EK) DVD±RW Dual Layer...
No installation disc for lacie d2 dvd rw
You shouldn't need an installation disk, just burner software. May I suggest this free burner software? Infra Recorder. I used to use
Nero, but switched to Infra Recorder, and like it Much better!
1.Info about Infra Recorder on Wikipedia.org,
http://en.wikipedia.org/wiki/Infra_Recorder
2.Infra Recorder homepage,
http://infrarecorder.org/
On this homepage you may want to go to the right, and click on
-> Screenshots, under the Pages heading.
If the Lacie D2 DVD-R/W burner drive is the only optical drive installed, Windows should 'see' it as new hardware. ("Found new
hardware" "Found Lacie D2 DVD-RW")
Be sure the 4-pin Molex power connector, is installed in this optical drive, also the interface cable, and the 4-pin audio cable.
May 14, 2009 | LaCie d2 DVD-RW Burner
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
Lacie external dvd burner not detected
DO YOU HAVE THE DRIVERS FOR THE BURNER CORECTLY INSTALLED ?
TRY IT ON A DIFFERENT COMPUTER TO SEE IF IT WORKS.
IF IT DOESNT YOU MIGHT NEED TO CHANGE EIGHTER THE DRIVE OR THE BURNER
Dec 30, 2007 | LaCie d2 DVD-RW Burner
LaCie DVD RW won't open
use a paperclip and manually eject the disc....recycle the unit, power it off then wait then power it back on and it should be seen be available again i hope this works for you ps put paperclip into tiny hole in front of disc drive....thx
Jul 06, 2007 | LaCie (300978) DVD RW Dual Layer Burner
Computers & Internet Logo
64 people viewed this question
Top LaCie Computers & Internet Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
