Question about Janome Sewing Machines
I have a Janome 500e. The needle threaded will not slide down it is somehow jammed? Any other deals what I need to do? Thank you
Posted by Tammy Wiper on
pawnpower
    Master:
  • 851 Answers
Contact a repair facility to get trained guidance.
Posted on Mar 25, 2018
5 Related Answers
coesew
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
sewtexas
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
Anonymous
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
Anonymous
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
Needle threader on my Janome 500E is stuck. I'm fed up with it or can I fix this myself or do I need to go to the repair shop?
Needle threaders tend to be problematic on most/all sewing machines, usually because they are so fragile. It may be bent, rotated, or even broken. You can probably take it for service.
Here's a hint for manual threading: Lick your index finger, swipe it across the back of the needle eye, then aim the thread point just above the needle eye and slide it down. Usually, it will pop right through.
Jun 26, 2018 | Janome Sewing Machines
How do I draw up the bobbin thread on my janome 4400
According to the manual on page 12 it appears to be like most machines:
https://www.janome.com/siteassets/support/manuals/economy-models/inst-book-7318-english.pdf
If you are having problems it could be because there is an issue with your bobbin ... or worse case that somehow the timing is off and the hook is not catching the bobbin thread ... but usually that can make a big thread mess underneath
Jan 13, 2018 | Janome Sewing Machines
Janome 350 embroidery machine......when I try to rewind the thread, ( shifting the stick to the right ) the needle keeps moving up and down.....any kind of help would be very appreciated.....the deale
Try to find the exact spot on the wheel to make the needle stop. Try different spots to get the one that does not move. You may need a service. You could also remove the thread until you are ready. The needle would go up and down but without thread will not cause havoc.
Jul 29, 2014 | Janome America Inc 350E Memory Craft...
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
Janome jd 1822 when i'm doing zig zag, the thread is missing stitches and also my threads keep breaking
rethread the machine getting every thread guide
check the thread tension 3 or 4 is usually good
Change needle--make sure the flat side is toward the back of the machine & that it's insert as high as it will go--make sure the needle bar is raised to it's highest position
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin that the bobbin is wound correctly & put into the bobbin case or shuttle correctly
here a tip about needle & thread compatability
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 24, 2010 | Janome Sewing Machines
My Janome mini compact will not sew through a double layer of flannel. I have tried changing the tension.
sometime the needle & thread are not compatable--try this & see if it work for you
Oct 14, 2010 | Janome Mini Compact
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome 10001
This is a protection mechanism of the machine when it believes there is too much strain on the motor.
Check the hook race/bobbin area...for lint or thread jam....also check the couterweighted cam that drives the needle up & down, as ofter thread will catch and be wound around the shaft near the take up lever.....open the door on the Left (Face Plate) and where the shaft comes through the body is where to look, move the handwheel slowly and watch for threads....remove them gently by unwinding, be patient as they may be well jammed.........DO NOT pull and break them !!
If you are convinced there is nothing jammed & if all appears clear, there are 2 possible scenarios, and I am afraid you are not likely to be too pleased by either of them.........please don't shoot the messenger.
The DC motor is failing, or
The "A" board has problems.
Janome have a 5 year warantee on the Circuit board and will replace it if it fails within this period.
This is a complex and valuable machine and may need the services of a well qualified Janome Trained Service Technician, not just any old hack repairman.
Protect your investment.
Best Wishes and hopes it's just the thread jam.
Mar 12, 2008 | Sewing Machines
Open Questions:
Sewing Machines Logo
507 people viewed this question
Top Janome Sewing Machines Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
