Question about Sport & Outdoor - Others
How to erect rough it 8 person tent - Sport & Outdoor - Others
Tom Chichester
    Top Expert:
  • Sport & Outd... Master
  • 57,436 Answers
Request instructions from Rough It.
Posted on Feb 07, 2018
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
Posted on Dec 16, 2008
Anonymous
SOURCE: erect a tent
start with the two longest poles and feed them through (every pole is colour coded so you can't go wrong), that will give you the main shape. peg each corner, once done start with back door section and feed the shorter ones through the loops when done peg it down. then do the same with the other two sleeping sections. finally the front door section (the black/grey coded pole) the pole has a curve which positions in the middle,get that pegged down and put the guide ropes in and it tight. then you can fine tune the rest of the tent sections, once you have everything how you want it, then put guide ropes in. it takes 15/20mins with two people to get everything up, after that it takes 15/20mins for one person to fine tune. hope this helps, if this is your first time putting up the hartford xl it'll take you about 1hr 15mins cause it did me. but it gets quicker with practice.
Posted on May 18, 2009
Anonymous
SOURCE: No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Posted on May 20, 2009
Anonymous
SOURCE: how do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Posted on Apr 08, 2010
brian soufane
  • 693 Answers
SOURCE: I need assembly instruction for 8 person cabin
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Posted on Oct 23, 2011
    I am in need of an instruction manual for a Swiss Gear 3 room 16×10 Dome Tent model # 36205
    First, I'm not a Swiss Gear representative.
    * check your warranty. Call for support
    *** following is for information only.***
    * Specs; https://www.amazon.com/swissgear-3-room-dome-tent/dp/b000iuxjpk
    * customer's attempt to erect 8 person tent; https://www.youtube.com/watch?v=hEJqXi3rWmE
    * Customer's review of 3/4 room tent; https://www.youtube.com/watch?v=EYH3lzcrGx4
    * Kmart; https://www.kmart.com/swiss-gear-3-room-family-dome-tent/p-9990000047088311P
    * Cheap-Price.net;https://w.cheap-price.net/store/SwissGear+16%27+x+10%27+Family+Dome+Tent+(Sleeps+8)+(36205)/4697886/
    * No Model # (Swiss Gear site); https://www.swissgear.com/catalogsearch/result?q=Tent+model+36205
    * Note Wenger does not make tents; https://en.wikipedia.org/wiki/Wenger#Other_products
    * 14x10' review; https://www.youtube.com/watch?v=KVoXQisnLaw
    * forum found a link but it's down now; https://answers.yahoo.com/question/index?qid=20090515164308AAXDSM3
    * Official(?) tent demo; https://www.youtube.com/watch?time_continue=7&v=_9BGvyF4vOw
    * Family dome tent; https://www.youtube.com/watch?v=o4eXG-T33cU
    * looks like only Amazon supports this brand. I suspect "Wenger" the official Swiss brand has been after them for using their name.
    Aloha, ukeboy57
    Aug 28, 2018 | Sport & Outdoor - Others
    Instuctions for Ozark tent
    Stacy, Check the attached links tent setup ,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Ozark trail 8 person instant tent
    Assembly Instructions for Ozark Trail Tents
    How to Assemble an Ozark Trail Tent
    ozark 8 person instant tent Google Search
    Jun 08, 2016 | Camping, Backpacking & Hiking
    Instruction manuel pdf 16x8 tent sleeps eight people
    Videos here
  • Ozark trail 8-person instant tent - YouTube www.youtube.com/watch?v=HOVGTmbKEZ0
    • BY NICK CRISCIONE
    • 5 MIN
    • 86K VIEWS
    2013-06-13 · Video embedded · Ozark trail 8-person instant tent Nick Criscione. Subscribe Subscribed Unsubscribe 15 15. ... Ozark Trail 10 person 3 room cabin tent - Duration: 8...
  • Ozark Trail 8-Person Dome Tent - Walmart.com www.walmart.com > ... > Camping > Tents & Accessories > Tents Ozark Trail Weatherbuster 9 Person Dome Tent with Two Bonus Queen Airbeds Value Bundle
  • Ozark Trail Tent 13 x 9 - Instant Tent - YouTube www.youtube.com/watch?v=PmZx-p3fYkk
    • BY FABIOMEGIATI
    • 2 MIN
    • 286K VIEWS
    2013-09-29 · Video embedded · Ozark Trail Tent 13 x 9 - Instant Tent fabiomegiati. Subscribe Subscribed Unsubscribe 208 208. Loading ... Ozark trail 8-person instant tent ...
  • Setting up my Ozark Trail instant tent - YouTube www.youtube.com/watch?v=xzU9uiPswP0
    • BY THE LONE WOOD ELF
    • 11 MIN
    • 58K VIEWS
    2013-03-30 · Video embedded · Setting up my Ozark Trail instant tent ... Ozark Trail Tent 13 x 9 ... Quechua Waterproof Pop Up Camping Tent 2 Seconds +IIII, 4 Man ...
  • Ozark Trail 12' x 8' 6-Person Dome Tent Reviews ... www.trailspace.com > Hike and Camp > Tents and Shelters
    • 2.5/5
    • 18 REVIEWS
    Ozark Trail 12' x 8' 6-Person Dome Tent. by Ozark ... Following all instructions included with the tent, ... The Ozark Trail 12' x 8' 6-Person Dome Tent is not ...
  • Family Camping Tents : Tents - Walmart.com www.walmart.com > ... > Camping > Tents & Accessories > Tents Tents > Family Camping Tents; Refine. Store availability. ... Ozark Trail 8-Person Family Cabin Tent with Screen Porch. 4.0 stars 4.0 (14) ratings. Free shipping ...
  • Ozark Trail 8 Person 2 Room Instant Cabin Tent - Walmart.com www.walmart.com > ... > Ozark Trail 8 Person 2 Room Instant Cabin Tent Ozark Trail 8 Person 2 Room Instant Cabin Tent; Back. Customer reviews. ... ozark trail tent. 6/10/2015. Customer review by hhhh. 5.0 stars 6/10/2015 by hhhh.
  • How to Assemble an Ozark Trail Tent ' Trails.com https://www.trails.com/how_841_assemble-ozark-trail-tent.html How to Assemble an Ozark Trail Tent. ... The easiest way to do this is to position one person on each end of the pole ... Assembly Instructions for Ozark Trail Tents
  • Ozark Trail 8 Person Instant Cabin Tent Review - amazon.com www.amazon.com/Ozark-Trail-8-Person-Instant-Cabin/product-reviews/... Bought the Ozark Trail 8-Person Instant Cabin Tent for a camping trip that was 1 week away. ... Ozark Trail 8 Person 2 Room Instant Cabin Tent Orange/Tan.
  • Ozark Trail Family Dome Tent 15' X 9' Instructions https://bepesepa.files.wordpress.com/2015/10/ozark-trail-family... · PDF file Ozark Trail Family Dome Tent 15' X 9' Instructions ... Ozark Trail 8 man tent 16 x 10 family dome tent ... Ozark Trail Family Dome Tent 15' X 9' Instructions
  • http://www.bing.com/search?q=Instructions+for+Ozark+8+man+tent&qs=n&form=QBRE&pq=instructions+for+ozark+8+man+tent&sc=0-33&sp=-1&sk=&cvid=7A70D36988944F338B1525CBCDCB0B19
    Jun 08, 2016 | Sport & Outdoor - Others
    Anyone know where I can get an instruction manual as i have no idea how to erect the two side tents
    Hi Debbie:
    If you Google the make and model of the tent with the words "assembly instructions" or "picture" you should get all the info that you need.
    Example..... Google "coleman tents" and you will get this link
    https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=coleman+tents
    It will give you lots of options to look at.
    Mar 14, 2016 | Sport & Outdoor - Others
    I have had a tent donated to our agency. Where can I get directions for erecting and finding missing parts?
    This tent was made by NorthPole, which has closed its parts department. Check this notice, which does list some places you might be able to get some parts.
    I caution you that this was a department store tent, made to hit a price point, and sourcing a few parts might cost far more than the tent it worth.
    Aug 05, 2015 | Northwest Territory Family Cabin 8-Person...
    Need instructions for putting up a tent please
    I don't know what kind of tent you have but there are many videos on youtube.
    erecting tent YouTube
    building tent YouTube
    making tent YouTube
    Aug 15, 2014 | Sport & Outdoor - Others
    What is a pop-up tent?
    Pop-up tents are self-erecting tents that can be set up in under 2 minutes.
    Sep 10, 2012 | Camping, Backpacking & Hiking
    How much does an 8 person tent cost?
    I've seen 8 person tents for a range of prices. Target had one for $150 but I've also seen tents for $500.
    How do u erect a lichfield challenger 5 tent ?
    Aug 06, 2009 | Sport & Outdoor - Others
    Erect a tent
    Jan 21, 2009 | Sport & Outdoor - Others
    Sport & Outdoor - Others Logo
    502 people viewed this question
    Top Sport & Outdoor - Others Experts
    Tom Chichester
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
