Not sure if you've reset it before but here are the directions. Pay attention to last paragraph.
If you have done this sorry for not having another answer.
The trick is to know that only the channel preset button labeled 1,2,3,4 are used to enter the PIN - each channel button is used to increment the value of one digit on the display. Channel preset '1' increments the first digit, '2' the second, and so on. Each press of a channel button increments the corresponding digit by one, cycling back to 0 and around again.
So to enter 1924 as a PIN, you'd start with the display reading '0000' and press
- preset 1 once (increment 0 -> 1)
- preset 2 nine times (increment 0 -> 9)
- preset 3 twice (increment 0 -> 2)
- preset 4 four times (increment 0 -> 4)
The last one's easy, as the radio unlocks as soon as you hit the right code so you just keep pressing preset button 4 'til it unlocks! (i.e. it's a 4 digit PIN but only as secure as a 3 digit one.
SOURCE: Cannot enter radio code
Disconnect the battery for 5 minutes and then try again, the program may be locked, make sure you follow the code entry instructions exactly, or it will also lock you out every time.
SOURCE: reset code for 2006 nissan maxima radio...
just changed battery,,all good,,radio is out,,tried fuses ,, what can i do to get the radio back on...
SOURCE: xtrail 2003 flashing airbag light
CODE READ SYSTEM ERASE FAULT CODES IF PREVIOUSLY NOTED CODES RETURN THESE WILL REQUIRE REPAIR AT YOUR LOCAL SERVICE CENTRE
SOURCE: 06 Nissan xtrail fault code p0335
Get the Chilton book of your make and model, they include wiring diagrams. Mine is a complete lifesaver. They usually run around $25 and you can get one at most of your auto parts stores. If you plan on working on your own vehicle it's a must.
