SOURCE: Lost owners manual
Here is the link for your owners manual: http://legacyproducts.tdk.com/support/pdfs/5900UserManualEN.pdf
SOURCE: Recording
You just need to plug your mic into a mixing board, and then take an output off the board into your 5900.
SOURCE: TDK CD Recorder DA-5900 owners manual PDF format
http://search.yahoo.com/search?p=d-unlock+tdk+%22da-5900%22&fr=yfp-t-501&toggle=1&cop=mss&ei=UTF-8
Link to PDF manual for TDK DA-5900.
enjoy...
SOURCE: How to record from the turntable using the TDK DA 5900
you need to run your rca cables from your amp/mixer depending on what your using,from the outputs into the inputs on cd recorder.
trhen make sure youve got the right cds cause i own a sony cd recorder an can only use sony digital audio cds,so you want to check that.
there should be a record button on unit press it and then play and you should be away.good luck any problems ask
