Question about Locks & Locksmithing
I work at a hotel and had to change batteries in all unican locks and i have 1 that has a solid red light and will not let me program
Not sure the model but is older and i use a kaba generation 4 unit
Posted by Robert Fedele on
5 Related Answers
Anonymous
  • 741 Answers
SOURCE: battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Posted on Jan 01, 2009
Anonymous
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
Coaltowner
  • 963 Answers
SOURCE: Need a instruction manual for
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Posted on Mar 06, 2011
Coaltowner
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Anonymous
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Posted on Mar 08, 2011
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
Kaba ilco series is accepting the cards but isnt opening the doors
I suggest that you contact Kaba Ilco directly with this problem. BE SURE TO HAVE YOUR MODEL #, AND SERIAL # & PURCHASE DATE HANDY IF POSSIBLE!
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jul 22, 2012 | Locks & Locksmithing
Hi i have got a Kaba 1000 series but the buttons are loose and not pressing in do you know what the problem is???
It may be that you don't have the installation set up for the proper thickness of the door. But your best bet is to call the customer service for Kaba Ilco and describe the problem. The toll-free number is 800-849-8324. They are located in North Carolina, so the best time to call would be during east coast business hours. Be sure to have your model number, purchase date, etc. handy when you call.
Here is a link to their website:
Good luck--and please provide feedback if this helps!
Aug 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Code dont work,key rod dont seem to work,cant change code.
Yours is an unusual problem. Therefore, I suggest that you call Kaba Ilco during regular business hours for assistance. Toll free: 800-849-8324 Be sure to have the model number and any other pertinent info on your lock ready if you call.
On the net:
1-800-849-8324 (option 3, and then option 6)
Aug 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How to extend or reprogram kaba machine expired date for authorised master key?
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
May 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
WE HAVE THIS LOCK INSTALLED AND IT HAS THE TYPICAL FACTORY SETTING CODE (2/4 THEN 3). WE DON'T KNOW HOW TO CHANGE IT! HELP
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Jan 06, 2011 | Simplex Kaba Ilco Unican LP1000...
Zero old key code and enter new key code on KABA electronic keypad
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
Sep 22, 2010 | Simplex Kaba E-Plex 3000 Narrow Stile...
My new wireless keypad is not being recognized. WHen I push the "Learn button on the opener it does not flash.
Press and immediately release the learn button and then walk over and key in your 4 digit PIN and press enter. If your opener is older and the keypad is the new generation it may not be compatible with your opener. You need to make sure you take the model number off the motor unit when you order new parts or accessories. The model number starts with 139.
Sep 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Locks & Locksmithing Logo
422 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
