Cameras Logo
Question about Sony Cameras
A350 sony camera: - Location burnt fuse tried connect the camera to computer. - LCD screen AUO version to replace for genuine sony version, I need advice. - Ribbon cable LCD to main board required.
Posted by Carlos Villa on
5 Related Answers
res116
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email [email protected]
Posted on Jun 18, 2008
jimikid2002
  • 3 Answers
SOURCE: FZ-30 LCD flat ribbon cable broken
Part No is VYQ3473. You can order it directly from Panasonic. It will cost you 29 USD without taxes.
Jimi
Posted on Jan 26, 2009
Anonymous
  • 28 Answers
SOURCE: dcr dvd 306e camcorder where can i buy flat flexi cables
hi, from here you will get replacement of flat flexi ribbon cable for your camcorder http://judy-hydigital.diytrade.com/
Posted on Jan 19, 2010
Anonymous
  • 10515 Answers
SOURCE: Sony a350 lcd consumer replacable?
I am sorry to hear regarding this Problem. If you are good at Repairing electronics, you could Fix that. But, the Main Problem is LCD Screen. Sony Does not allow the Screen to be Sold Separately and they would charge around $125 - $150 to get the Screen Fixed.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 12, 2010
Anonymous
  • 11967 Answers
SOURCE: sony a350 wont transfer images to pc
Do what the pros do...use a card reader.
Posted on Apr 05, 2010
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
My Sony DSLR-A350 was working fine. Took dozens of pictures. When I turned it back on to transfer to the computer, it wouldn't turn on. I knew the battery was charged but tried another one, same thing....
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hope i helped you.
2helpful
View screen on DSLRA350K is broken
Part number of LCD (view screen) for DSLR-A350 is as follows..
180257011.. LCD MODULE (A027DN01 V1)
Available in Part Store for $99
If you are asking some thing else, let me know.
Hope this info will help you.
20helpful
4answers
Replace LCD monitor on Sony DSLR a350
The You-Tube video is useful. http://www.youtube.com/watch?v=dP0Yr4YXM9Y
Care must be taken when removing the ribbon-cable connector from its mating half on the camera ribbon-cable.
The black strip on the mating connector has to be flipped back, away from the display ribbon, to release the display ribbon.
Then after locating the new ribbon fully home, the same black strip has to be flipped forward in the direction of the display ribbon and pressed down to clamp this connector in place. All this is shown, but quickly in the video.
Do not touch the bare surface of the new display or the inside surface of the removed display protective surface which has an optical coating which easly shows fingerprints.
LCD needs replaced as it got damaged on Sony Alpha DSLRA350
http://cgi.ebay.co.uk/LCD-Screen-Protector-glass-For-SONY-a300-a350_W0QQitemZ220470689741QQcmdZViewItemQQptZUK_Photography_DigitalCamAccess_RL?hash=item335513bfcd i have not bought this but it looks like it might protect the lcd some what but if you need the lcd protection when you are not using it then look at this http://cgi.ebay.co.uk/Hard-LCD-Cover-Screen-Protector-for-Sony-A350-PCK-LH3AM_W0QQitemZ180396635411QQcmdZViewItemQQptZUK_Photography_CameraLenses_Lens_caps_
LCD display
This 1.7" LCD is made by AUO and it is most likely defective. You may try reseating the internal ribon cable of the LCD connected to the printed circuit board by opening the camera back case (5 small screws) with a tri-wing screwdriver size #000. Care must be taken as the flash light charging circuit is active and touching certain area of the board may give a big shock once you have access to the internal guts of the camera.
LCD White-out
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
