Question about Kitchen Appliances - Others
Where can I get replacement foam seals for my seal a meal VS106/-B
Posted by Mary Bollmann on
5 Related Answers
Anonymous
SOURCE: rival seal a meal
where can i get an instrucion manual? i bought one from e-bay, but the instructions were gone
Posted on Oct 09, 2008
Anonymous
SOURCE: Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Posted on Aug 08, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Good Morning, I
I have seen many complaints about those things come to FixYa...It seems that the wire that makes the heat either becomes disconnected or breaks...as far as I can tell there is no fixing or replacement for that.
Wish that I could give you better news.....:-(
heatman101
Posted on Sep 20, 2010
GetMeOttaHere
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
pdarrach
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
My rival seal a meal does not vacumn the air out when it is sealing. what is the problem and how do I fix it
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Jun 06, 2016 | Rival Kitchen Appliances - Others
Where can I find Teflon tape to cover heat strip on seal-a-meal vacuum system. Model vs106
Firstly, visit their website and look for a spares service. Ordinary Teflon plumbing tape MIGHT do the job but I'm not too sure how you would go about fixing it into place.
Mar 24, 2015 | Kitchen Appliances - Others
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
You can fix it yourself for $3 or so if you look for the thermal cutoff (a resister looking device) You can get this at a quality electronics supply. If you just cross the cutoff it will work but could be a fire hazard.
Oct 12, 2013 | Rival Seal-A-Meal VS106 Vacuum Food Sealer
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012)
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Nov 30, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Good Morning, I have a [email protected] Vacuum Sealer Model # VS106/-B....Problem I am having is, it has stoped sealing the bag....Heat strip is not hot at all....Can you help me.....I purchase it just...
heatman101
Sep 20, 2010 | Microwave Ovens
Kitchen Appliances - Others Logo
595 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
