Question about Icom Radio Communications
ICOM A110 airband radio failed to power up with 13.6 volts applied
13.6 volts trace tdo power input on mother yet unable to power up please help
Posted by patric olize on
Clint Millett
    Habit-Forming:
    Scholar:
  • 97 Answers
Here's a link to the service manual - www.shercoares.org > doc_files > manuals > ica110_sm. This may help. Have you checked both fuses? They should both be about 10A. Use a meter to check them. A visible check may not show the fuses open.
Posted on Nov 10, 2019
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: OLDER ICOM RADIO ICBP5 AND A REGENCY U156B
Hi, The Icom radio models start with IC followed by numbers and then letter(s). The BP5 is the model of the battery pack. Pls post back. I'm not familiar with Regency U156B. However, there is a Regency RU156 which is a 16 channel UHF 25watt mobile radio which could either be crystal controlled or PLL diode matrix. Regency was reported sold to the BK Relm Company, which no longer supports older Regency Radio Equipment. There are a few sites on the Internet where you can get hold of a user's manual (some for a fee) like http://www.bearcat1.com/manuals.htm. Hope this be of some help/idea. Post back how thin gs turned up, the Icom model or should you need additional information. Good luck and kind regards.
Posted on Oct 03, 2007
Anonymous
  • 319 Answers
SOURCE: No Life, does NOT power up, Fuse is OK
There is apparently some component in the stanby circuit that is malfunctioning. There may be a milli amp fuse off the standy transformer secondary. Check - don't confuse with a resistor. It may read 2 ohms or less
Posted on May 10, 2008
Anonymous
  • 148 Answers
SOURCE: Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
Posted on May 17, 2008
Anonymous
  • 463 Answers
SOURCE: icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Posted on Mar 20, 2009
liammahe
  • 3 Answers
SOURCE: My icom 706 mk2g powers
Hi
I had a similar problem on my 706 MK1. The problem was corroded connections on the white power connector at the rear, When on tx the voltage drop across this connector was great enough to switch the radio off. try cleaning/re-seating this connector
EI4HO
Posted on Oct 16, 2009
Icom A110 will not power up
Start by testing the fuses
Feb 05, 2018 | Car Audio & Video
How can i fix a interface of icom ic-a110´s microphone?
Hi Yanielki,
You want to interface a IC-A110 mic with what other piece of equipment?
Are you looking for a wiring diagram?
What's the problem?
Explain more and myself and plenty others would be happy to help.
Regards,
John
Aug 24, 2017 | Icom Radio Communications
Icom IC-A110 VHF Airband radio will not power up while connected to power supply
Check power supply with multimeter. If OK,then insert power connector to device, while switched on, gently wiggle connector in its socket to see if anything happens, it may come on sporadically. That would tell you it's a faulty connection inside,the terminals may be worn.
Apr 03, 2014 | Radio Communications
Icom IC-A210 wont turn on
Need to check your input power lines for any voltage applied. And also need to ensure it is properly grounded.
http://www.icom.co.jp/world/support/download/manual/pdf/IC-A210_Inst_4.pdf
Jan 06, 2014 | Icom IC-A210 Panel Mount COMM Transceiver
Icom a 110
Contact Icom's service center. Their info is available at www.icom.com.
Aug 10, 2013 | Icom OPC-871 Headset Adapter for IC-A110...
Unable to transmitt
Read your Radio and enable transmit
May 24, 2013 | Icom Ic-a110 Vhf Mobile Aviation Radio
IC-A210
I can to see on Panel Screen ICOM IC-A210 message RX error
Feb 01, 2013 | Icom IC-A210 VHF Airband Transceiver
Rx error on a210
replace the riben cable from head unit to main board,£2 from icom uk. regards gw0dxo
Jan 16, 2013 | Icom IC-A210 VHF Airband Transceiver
Ic a110 power problem
Hi Joshua,
Not enough info provided, from you.
IC a 110 power problem means very little.
IC indicates to me that you havs an Icom radio, is that correct?
a110 is confusing me though. What exactly are you trying to say here?
To assist you in finding the answer, I need much more info:
1. The make of the radio i.e,. Icom, Motorola etc,.
2. The Model Number ie, IC-XXX, etc,.
Then I require as much info as possible regarding the problem
By just posting what you have doesn\'t help me help you.
Please reply with the above requirements, and I\'ll find a solution for you.
Cheers,
Peter
Dec 14, 2012 | Radio Communications
Radio Communications Logo
128 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
