Question about Dryers
We need mounting screws for the fan we purchased. They were not in the box when we opened it. Where can we get the mounting screws?
Jaye t rock
    Sergeant:
  • 264 Answers
You can get mounting screws at Walmart Home Depot or somewhere like that
Posted on Feb 06, 2018
Vernon Taylor
  • 6,659 Answers
If the screws should have been supplied you should complain to the supplier but such things increasingly are becoming separate items, just another way of boosting profit.
Most repair shops, car workshops and keen diy-ers have a wide selection of screws and bolts.
Good hardware stores also have a wide selection...
Posted on Feb 05, 2018
  • Anonymous Feb 06, 2018
    So you are telling me that the Co will not send us the screws
  • Vernon Taylor Feb 06, 2018
    Not what I am saying at all. First you have to ask if the screws should have been included. Only if the answer is yes can you expect the supplier to send you some, though the supplier might have some and sell them separately but first you need to ask...
1 Related Answer
mpcheeseman1
mpcheesman1
  • 1400 Answers
SOURCE: We have been given a Heritage Ceiling Fan - model
Hello
Lowes or home depot sells parts for ceiling fans.
Or contact the manufacture online with your model# and they will send them too you.
A link too your fan manufacturer.
http://www.hunterair.com/hunter-heritage-collection.php
Posted on Jun 10, 2010
The motor is not stable-therefore it bounces around & doesnt work-I believe it was assembled wrong I need directions for putting together
Goto a hardware store and purchase a balance kit. Follow the directions in the kit to balance the blades. Also make sure all the blade screws are tight, all blades have all the washers on them and that the motor is securely mounted to a FAN box. Regular light boxes often cannot hold the weight of a ceiling fan. A fan box has braces on it that expand into the ceiling joists.
Jul 19, 2016 | Dryers
Fan is 52" hugger style. I need the mount between the fan canopy & the outlet box in the ceiling.
Most likely need to contact manufacture of fan. What make/model of fan do you have?
Jun 19, 2015 | Dryers
Corsair h50
The installation and use of cooling fans in PCs is pretty straightforward once you understand the airflow layout and mechanical assembly.
You need to learn the necessary skills to make sure you are setting up your fans to direct the air where it will do the most good, as well as how to choose (and mount) the correct fan(s) for your situation.
Computer fans are manufactured in five distinct varieties: case fans, expansion-slot fans, hard-drive coolers, CPU fans and external drive-bay fans.
With case fans, there are several physical sizes that are measured in millimeters.
Another measurement the manufacturer will provide is the CFM (Cubic Feet per Minute) the fan is rated for.
As a general rule, the smaller the fan in size and the higher the CFM rating, the more noise it will create.
Before you purchase additional fans, open your case to see what kind of fans can be added.
The fan size must match the size of the opening in the case to be at peak efficiency.
You will need to establish you have expansion slots available if you want to add an expansion slot-style fan.
It is crucial you establish a pathway for the air being moved inside your case to follow.
As an example, having all the fans blowing air from the outside of the case to the inside is not as efficient as having fans on the front of the case blowing cool air in while the fans located in the back of the case are sucking out hot air.
It is recommended the best practice is to position a case fan in the front bottom of your case (bringing in cold air) and at least one fan mounted midway up the rear of your case (expelling hot air).
If possible, use two fans in the back to expel the hot air as a lot of it is being introduced by the CPU cooling fan.
The mounting of case fans is done by using four course-thread screws usually provided with the fan.
These screws are self-tapping and will be inserted through the hole in the case wall created for a case-fan screw, then screwed into the case-fan body mounting hole.
Make sure you use all four screws to hold the fan securely.
The installation of an expansion slot fan can target specific areas where heat is generated.
When mounting one of these fans, make sure the expansion slot fan is not in direct competition with the fan mounted to a video card.
Having the expansion slot fan blowing directly into the video card's fan, which is trying to blow out air, will defeat both of the fans' purpose.
Hard-drive coolers usually mount to the circuit board side of the hard drive and work to keep it cool.
Because of the location of most hard drives, there is very little disturbance from the air that is released from the hard-drive cooler to the airflow pattern mentioned earlier.
External drive bay fans can provide an enormous amount if airflow, assuming there is an external drive bay open.
http://www.homepcbuilder.com/lessons/installation/lesson04/lesson04.html
Jul 28, 2013 | Video Game Consoles & Games
Hello, I have a ceiling fan 44F8, motor C0006, but I don't have the screws to intall it on the ceiling nor the screws to attach the.. well not sure what the name is..perpelars? Where can I buy the...
betancurf - If you're missing that many parts, you're also going to need the mount for the ceiling receptacle box, and hopefully that receptacle box will support the fan while it's running.
The screws for the fan blades can be found at most home centers that sell ceiling fans. As can all the other mounting parts you'll need to properly install it.
Jun 09, 2011 | Heating & Cooling
Removing the cabin air filter on a 2001 mitsubishi galant
Open the glove box and empty the contents. gently push the glove box to the left and slide the stop toward you. Now slide the box to the right to get the left stop unhooked. Letting the glove box hang, look at the long thin plate on the fan shroud and undo the two screws holding it in. Now you can slide the cabin filter tray out of the fan shroud and replace the paper element. If you look at the fan shroud and see the rectangular slot but there are no screws in it , the cabin air filter has not been installed in your model. The rectangle can be cut out with an Exacto knife and the cabin air filter can be installed in the slot. You can purchase the cabin air filter tray, cabin air filter, and mounting screws at the Misubishi dealer. I purchased one out of an Eclipse at a salvage yard for $5 , washed it, and installed a new $10 dollar aftermarket paper element. I no longer have dust on my dash and it only cost $15.
Mar 27, 2011 | 2001 Mitsubishi Galant
I want to ad afan
Most cases already are set up for an additional fan. You may find which size you need in your users manual or online manual. You just need to size the fan with the opening and mounts, purchase the kit, it should come with a fan, screws, and a cable to get power to the fan. Installation is simple. Just make sure you get the right size though.
Aug 29, 2010 | E-Machines eMachines Desktop PC
REMOVAL FROM CEILING
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Exhaust fan has stopped working Need to troubleshoot
Even though this is a pain, I need to suggest that you perform the following:
Remove the microwave from the mounting position as follows:
1. Place a cardboard box of sufficient height to have the microwave rest on it with no more than about a 4-inch drop. Cover the box with a bath towel.
2. Using a power screwdriver, remove the 2 mounting screws located in the overhead cabinet base. (microwave front will tilt down onto the box)
3. Firmly lift on the rear of the microwave to unhook it from the wall mount bracket.
4. Once removed, pull some slack on the power cord.
5. Slide the box and microwave forward (toward you)....enough to see the fan blades
6. Place a small cup of water in the microwave and press quick start (30 seconds)
7 Look at the fan blades. If NO movement, open door. Hand rotate blades a full turn to ensure free movement.
8. Restart microwave. (fan blades move - Yes/no)
If No, check power cable that supplies internal power to fan. Be sure it is connectied.
If yes - but only a slight movement - it is clogged with grease...remove it and spray with lots of Ammonia to clean fan elements. Shake excess moisture off. Retest.(fan blades move - Yes/no).
If yes, reverse removal procedure and enjoy....
If no, Replace fan assembly
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cover does not attach to the universal bracket I purchased
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Jan 13, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Dryers Logo
272 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
