SOURCE: I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
SOURCE: cannot change aspect ratio
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Testimonial: "Thank you very much. That answers the question. "
