Question about Ricoh Office Equipment & Supplies
I have an af2027 that does not load toner, I changed dev but still no progress. The dev gears are still fine. What can I do to solve this problem?
Posted by Ramokanate Mohatlane on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
The toner bottle motor may be defective. you can test does it work in service mode under 5.Mode - output. find toner bottle motor and press on to see does it work. Or it can be engine stall and you need to make engine clear in service mode with SP- 5 801-002. and hen make developer initialization. For additional instructions please write a comment.
Posted on Jun 26, 2018
2 Related Answers
Anonymous
  • 682 Answers
SOURCE: Toner Light on
please check the following:-1-toner stiring roller in toner box is stucked and did not move to mix and supply toner-get toner box out and empty it from toner and clean it with air blower and check the condition of roller clean and lubricat the bearing carrying the roller-check toner motor is pluged firmly in its socket-go to rear frame and check toner selonid is working and in good condition-check gears that drive toner roller in good condition.
Posted on Apr 18, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: sharp arbc 320 toner cartridge drive gear
Your probably going to need the parts manual to get the part number for it. The service manual won't have that information for you. Copytechnet.com can get that information you need for you as well and a lot faster than you get on here since that site is usually for copier technicians only.
Posted on Jul 29, 2008
I have replaced my ricoh mechine with new tonner but still gives "out of tonner"what must be the problem?
Usually when it's not loading toner the dev gears on the PCU is worn out. You should call your nearest Ricoh agent for a service call let the technician come and fit new dev gears
1helpful
Add toner problem
Clean the toner hopper and check the dev gears on the drum unit. Usually thats the problem why its not loading toner.
How can i fix my aficio 2027 w/ loading toner error
Not loading toner is usually due to worn out dev gears in the PCU. Call your nearest Ricoh agent for a service call. A technician must come and fit new dev gears. Or the toner hopper is dirty and needs cleaning.
2answers
MP2000 not loading toner
please check if the toner is not lumpy cos this can also cause that.
or also check the buttom of the toner bottle since the moto and the bottle may not have the same format .
6helpful
Change developer for Aficio 1018
Open the front and right covers and remove the toner bottle holder unit.
Pull out the Photoconductor unit(PCU) with your thumb pressing on the latch on the left side of the PCU.
Separate the top part from(drum) the bottom part(developer unit), by removing the front piece 1 screw and rear piece 2 screws and 1 coupling(pull out).
Now remove 1 front screw, 2 rear screws and other 2 top rear screws to separate the top and bottom parts of the dev. unit.
Then place your finger under the front-side and rear-side flaps and push out so that the flaps pops off the peg.
Set the coupling removed, back to the shaft and turn the coupling to remove the developer from the roller.
Turn upside down the lower part of the dev. unit to remove all the developer by turning its gears.
Load new developer evenly in the openings of the lower dev. unit and pay attention not to spill developer on the gears.
Reassemble the whole PCU properly.
Reinstall back the PCU and toner unit and close the front and right covers.
Switch on the machine, enter SP mode- Clear key, 107, hold and press Stop key.
Enter SP 2-214 and execute to reinitialize the TD sensor.
Switch off and on the machine.
Good luck and please rate me, thanks.
1helpful
Colours are wrong
Most likely a toner spill down the back side of the carousel. Remove all the toner and dev unit and vac out any spillage from within the printer. DO NOT VAC THE DEV OR TONER UNITS.
Replace all the units and print about 200 full colour pictures (preferably a test chart - Gretag McBeth or similar) at full size (A4). See if the colour then begins to return to normal. If not, you will probably have to replace the dev units too.
Toner Light on
2helpful
Getting a error code C0F37 on a Minolta Dialta CF1501. What's the solution to solve this problem. Is it a Black Imaging Unit or ? Marino
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
