Question about Brother Sewing Machines
URGENT! LB 6800 brother embroidery machine has F05 speed sensor error! Please help.
Brother sewing/embroidery machine LB6800 is stopping mid embroidery and continuously beeping and showing F05 speed sensor. I understand I may need to clean the speed sensor? Where is it and how do I access it? I don't seem to be able to remove the front cover without breaking it... Please help! Thank you
Posted by Maddy Plimmer on
R.A. Ellis
  • Brother Master
  • 12,731 Answers
5 Related Answers
Anonymous
SOURCE: Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email [email protected]
Posted on Apr 11, 2008
Anonymous
  • 66 Answers
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
Posted on Jan 28, 2009
Anonymous
  • 46 Answers
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Posted on Jul 25, 2009
Anonymous
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
Anonymous
  • 53 Answers
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Posted on Jun 06, 2010
My brother sewing machine LB 6800 is showing FO5 speed sensor error what can I do to fix it
You may need to get the sewing machine serviced; the repair must be handled as if you are fixing a computer. The F05/F5 error indicates a problem with the timing shutter, the PCB board or the wiring between them.
If you are going to try this, first unplug the machine and check the wiring. Next clean the timing shutter if the wiring is undamaged. Replace the timing shutter if the error recurs. If the machine still gives the F05 error, the PCB board has to be replaced.
Some of the parts for the Brother LB6800 are here: https://www.sewingpartsonline.com/brother-lb6800-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=157.
I hope this helps.
Sep 29, 2018 | Brother Sewing Machines
How to digitize an image for use on a Brother LB-6800
Yes. PE-DESIGN is one of the programs allow you to transform pictures/images into embroidery. There are companies that will do it for you if you want only particular pictures done so that you won't have to purchase the program. There are other programs available and some of them are very expensive. I think that PE-DESIGN by Brother is one of the more inexpensive brands that are very good. Maybe I can help you if you send me a photo of what you would like to transform: [email protected]
Jul 01, 2016 | Brother LB-6800PRW Project Runway Limited...
I have a Brother Pacesetter PE - 100 machine where can I find or download a manual for this machine?
Search Results
    ETP027 - Brother International - Home Sewing Machine and ...
    www.brother-usa.com/.../accessorydetail.aspx?...ETP0...
    Brother IndustriesFind Dealer ... Download individual embroidery designs from Disney®, Nickelodeon and ... Fresh Green 100% Polyester Color Fast, High Shine Embroidery Thread ... BuyBrother Home Sewing & Embroidery Machines from Authorized Dealers ... PS3100,Pacesetter® PS3700, QC1000, SE270D, Super Ace I, ULT-2001C, ...
    Home Sewing Machines - Brother
    www.brother-usa.com/homesewing/software/
    Brother IndustriesIf the operating system of your computer is Windows Vista™, you can find support .... of design creation to owners of any Brother Pacesetter ULT model sewing machine. ... Click HERE to download "My Custom Design" Instruction Manual. ... If the software version of your PE-Design is Ver.1.x to Ver.5.x, an update program is ...
    Retired Products - Brother
    www.brother-usa.com/homesewing/.../retiredmodels.as...
    Brother IndustriesBrother - Your Home Sewing Machine and Innovis Embroidery Machine Choice. ...Find Dealer. >> go. Product Selector. Download individual embroidery designs from Disney®, Nickelodeon and more. Brother Sews ... View Details. Brother CS100T.CS100T View Details. Brother CS6000T ... Brother Pacesetter® PS3700.
    PE500 - Brother
Jan 26, 2016 | Brother Embroidery Machine Regular Hoop...
How can I get my machine to stop jamming
Have you tried oiling all moving parts. Go under presser foot under bobbin and remove all lint. Try to change the needle.
Oct 25, 2015 | Brother LB-6800PRW Project Runway...
Brother embroidery machine
Please contact your brother embroidery machine provider. Or you ask experience Brother embroidery machine designers.
Feb 16, 2014 | Brother Sewing Machines
My lb6800 says raise pressure foot bar and it is, tried unplugging, nothing helps. It sews when embroidery unit not attatched.
it sounds like the sewing machine needs to be checked
to see if there is somthing wrong with the computer in the machine.
Nov 05, 2012 | Brother LB6800PRW Mechanical Sewing...
Brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
Jun 26, 2012 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
437 people viewed this question
Top Brother Sewing Machines Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
