SOURCE: have everstart 24dc-6 boat battery is it 6 or 12 volt
Sounds like the Batteries we used in golf carts......Deep cycle and shoe is right 6 volt.
SOURCE: Battery in Jeep Grand Cherokee dead this am and
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
SOURCE: Included in my Ryobi printed
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
