Question about Motorola Televison & Video
Code to program a motorola remote 1072aba2-r to operate motorola dcx3400
Posted by ERNESTO MARROQUIN... on
2 Related Answers
Anonymous
SOURCE: Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Posted on Sep 08, 2008
Anonymous
  • 14 Answers
SOURCE: looking for tv code
Magnavox 0054, 0030, 0706, 0020, 0187,
0179, 0024, 0096
Posted on Sep 15, 2008
tip
Comcast Xfinity DVR motorola DCX3400 series want to skip forward 30 seconds?
If you are like me who used to have the satalite DVR you miss the skip forward function that some of the remotes have. With comcast or Xfinity remotes you can program them. Mine says Xfinity on the bottom and since I have no others to compare it to I cant say this will work on all remotes. Watch for the blinks as they will signify that everything is OK. If they dont give it a minute or two and then start over again pressing the buttons fully down. Since most of the button funtions are already taken, and at least on my NEW TV it didnt come with Picture In Picture funtion so these buttons are not being used by me. So lets use that last PIP minus button for this example. When you are done you can still reassign the Aux button back to say a DVD player or something, but only if it doesnt still work. This sequence just programs the remote PiP button.
Press the Aux button one time
Press and hold the Setup button until the Aux blinks 2 times
after it does enter these numbers 01376,
now the remote should blink 2 times again.
press and hold Setup again until 2 blinks
now press 994
and press the Aux button
Press the Setup one time and now enter the numbers 00173
Press the Cable button
Press the PIP Channel Minus at the bottom of the comcast remote and you will see the lights blink again at the top of the remote to signify 2 blinks that it is done.
on Mar 02, 2011 • Televison & Video
Program remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Motorola dcx3400 user guide not found on your list
Hi, Please follow the link from Motorola site DCX3400 Manual
Please don't rate until follow-up questions have been answered.
I have a Motorola DCT6416 PVR. Dog layed on remote and de-programmed. I can't find the program code to fix my remote control.
are you sure its not something simple like the remote is in the wrong mode. what lights up on the remote when you push buttons?
what isn't working? the cable box not responding? the tv not responding? nothing?
RCN's motorola code is 002 (actually i think the new remotes may be different), TV code could be anything.
FYI: battery cover on remote sometimes has directions for code search
hope something here helped
1helpful
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the...
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
8helpful
2answers
Want to program motorola remote to samsung tv
Samsung TV Codes: 10060, 10812, 10702, 10178, 10030, 10766, 10814, 11060, 11903.
Hope that helps!
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
