How to Turn Off Screen Overlay on Android:
1) Open your Android’s Settings. It’s the gear ( ) icon typically found in the app drawer.
This method is helpful when you see an error message that says “Screen overlay detected. To change this permission setting, you first have to turn off the screen overlay from Settings > Apps.”
The error sometimes occurs when you update an app that supports screen overlays.
2) Scroll down and tap Apps. This may be called Applications on some devices.
3) Tap ?. It’s at the top-right corner of the app list.
4) Tap Configure Apps.
If you don’t see this option, look for a gear icon ( ) or Application Manager.
If you tapped Application Manager, tap More at the top-right corner of the screen, then proceed to the next step.
5) Tap Draw over other apps. This may be called Can appear on top on some devices. If you don’t see either of these options, it’s probably buried in a sub-menu. Tap the menus until you find it.
6) Tap the app that gave you the error message. Common apps that have screen overlays are Messenger, WhatsApp, Clean Master, Drupe, screen recorders, and Lux.
7) Slide the “Permit drawing over other apps” switch to the (Off) position. Screen overlays are now disabled for this app. You can now return to the app in which you saw the error message to try again.....
1. Open your Settings.
2. Tap Apps.
3. Tap this icon ?
4. Tap Configure Apps.
5. Tap Draw over other apps.
6. Tap the app you were using.
7. Slide the switch to the Off position.
Hope this help.
1. From your home page go to Main Settings by pulling down the Notification Bar and clicking on the Settings icon at the top right of the screen. (it's gear shaped)
2. Scroll down the Settings menu, and click on Applications under the Phone section about two thirds down the page.
3. At the top of this new menu click on "Applications Manager".
4. In the top right corner of the Applications Manager menu click on "More"
5. Now a click on "Draw over Other Applications"
6. Scroll down this menu and find the offending application, in this example "Facebook"
7. Click on the button to the right of your offending application to deselect it.
8. Close out of the Settings menus.
NOTE: Alternately, deselect all the applications under step 8 except those you know pop up over other applications such as messaging, for example.
SOURCE: Java Applications Not Working On My Cingular Se 810i
i understand ur problem , but it has been very frequently noticed that most of the application available on net are not compatible with Sony Erricsson handsets...plz make sure that the apps u r trying to install are compatible for ur phone , it is a clear java version mismatch...
SOURCE: Java Applications Not Working On My Cingular Se w810i
Reinstall the Firmware or updating to the latest software from S.e 's site.
that must be then some hardcore java errors?
