Question about Precor Efx 5.21i
XTR stoped switching to backwards motion. How do I reset the program?
Posted by joey pena on
Stephen Miller
  • Precor Master
  • 1,645 Answers
Driver side seat will move up and down but want move forward or backwards what can be the problem
It sounds like the motor for the forward/backward motion is out. Or the switch is bad.
Oct 11, 2017 | Seat Cars & Trucks
I have a 2006 Hyundai sonata... and I have changed
use a scanner to reset the ecm program as removing the battery sometimes corrupts the CPU settings
Oct 19, 2014 | 2006 Hyundai Sonata
20822 Department shredder
The motor has a feature to go forward and reverse and thus the forward (paper in) control has been compromised. The problem can be the switches. A rocker switch when in one position may control the forward motion or backward motion, therefore if the switch fails only one side is working. Then there may be two small switches on the so called rollers (Cutters) that sense the input of paper into the cutters thereby starting the motion and shredding procedure. If a sensing device is broken, only the unaffected switch works. Repair is usually expensive, thus a replacement is in order.
Dec 18, 2013 | Dahle Office Equipment & Supplies
I start the track and it moves until I step on it then it stops
see the video and lube too the rollers bearing front and back.
However if the problem persist. Test the input voltage motor if there are the motor is faulty. Test the output voltage terminal control board if there are Not FOR the input voltage motor, the board is Faulty. replace
Oct 08, 2013 | FreeMotion Xtr 90 Treadmill By Free Motion
Precor Efx 5.21i Logo
61 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
