Question about Kenwood KDC-716S CD Player
Kenwood kdc-716s radio is closed with not face plate on it, cant get it open, what do i do now?
Posted by moonwalker68 on
Anonymous
  • 78 Answers
Firstly you should remove the power from the unit for a few seconds to reset it. if this doesn't fix it you can remove the top lid and you will see the motor that rotates the fascia, if you unplug the flexible cable that powers the motor and put 6volts on the motor contacts till the fascia rotates and then plug the flexible cable back put the fascia back on and plug the power lead back on to the radio
Posted on Nov 26, 2007
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
KDC-716S sometimes plays CD, other times just tray drop
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 01, 2009 | Kenwood KDC-716S CD Player
Got a Kenwood KDC-PSW9524. For some reason the
MINE DID A SIMILAR THING THE FACE PLATE IS MOTORIZED AND GOT STUCK CLOSED SO INSTEAD OF BREAKING IT I FOUND THE RESET BUTTON ON THE RADIO IN THE FRONT ON THE SIDE ITS A LITTLE TINY BLACK HOLE STICK SAFETY PIN OR SOMETHING IN IT.BUT BE CAREFUL IF YOU DONT KNOW YOUR RADIOS SECURITY CODE IF NOT SURE WHILE STILL ON GO INTO THE OPTIONS AND TURN THE CODE ACCESS OFF.!
Apr 12, 2009 | Kenwood KDC-PSW9524 CD Player
Kenwood KDC-716S
FLEX CABLE has been worn out, its thirty bucks and easy to install.
Oct 02, 2008 | Kenwood KDC-716S CD Player
Kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Dec 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
Face plate will not close, retract into dash,radio plays!
Get your Shifter shortened, it will give you faster more controlled shifts, and keep your knuckles out of the dash.
Nov 18, 2007 | Kenwood KDC-MP628 CD Player
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Mechanical Face Plate Assembly
I dont have a manual but you might be able to download a service manual from the following website , I hope its helpful since some parts may not be serviceable on that face plate......... http://www.user-manuals.com/service-manual-KENWOOD-KDC716S.html
Mar 31, 2007 | Kenwood KDC-716S CD Player
KDC.716S Mech error issue
Try the tiny reset button on the front just below the volume down button.
Nov 10, 2006 | Kenwood KDC-716S CD Player
Kenwood KDC-716S CD Player Logo
128 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
