Question about Amana Refrigerators
Amana refrigerator Light and refrigerator/freezer top freezer model are both off. Is there a reset button? Both were fine last night.
Posted by Gini Hyman on
Sal De
  • Amana Master
  • 2,699 Answers
If everything is out even the lights check the plug and make sure the fuse or breaker isn't popped,unplug the fridge and plug a lamp or something in there to check power,i've seen fridges on a gfi plug so check that too,but sounds like no power to fridge.next time send the full model number off of the machine,
Posted on Feb 06, 2018
  • Sal De Feb 06, 2018
    you could have a bad timer or cold control and the light could have failed from the heat but try banging on the control,not to hard,it can stick when it fails and sometimes a good wack will get it going the timer is also there where the cold control is,there's a hole below the timer,if you stick a flat head regular screw driver up in there you can turn the timer out of defrost, just one or two clicks,if everything starts to run the timer is bad but i would check them if you unplugged the fridge and plugged something else in the plug to make sure you have power there
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Anonymous
SOURCE: have an amana refrigerator model BC121VW bottem freezer
In the back of the refrigerator, there should be a vent. Put your hand over it and see if air is coming out. This will tell you if the fan the other poster mentioned is working. If no air is moving then either the fan is bad or the channel is plugged. If only a small amount of air is moving through, open the freezer door and check the air flow again. If the flow got much better, then the return channel is plugged. Try these steps, and if they help post back and I will tell you what to do next.
Posted on Aug 11, 2009
Light and refrigerator/freezer (top freezer model) are both off. Is there a reset button? Both were fine last night.
check for power at receptacle, if getting power you most likely have a bad overload relay located on compressor which is sometimes combined with start relay these go bad often
Feb 04, 2018 | Refrigerators
Refrigerator stop working, freezer fine
What is the model number of your unit?
Oct 31, 2012 | Amana Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
Amana fridge/freezer compressor problem
Unplug unit.
It's not possible to tell which without replacing the starting system. Hard start kit would be fine. RCO410 is common. If it starts the unit the next check would be an ampmeter clamped onto one of the power leads. The ampmeter for refrigerators of that age may read around 2-5 amps when running. If it's much higher than 5 Amps after it's running be prepared to replace the compressor. Maybe it won't quit today...but it won't last with high amperage. If it doesn't start with this kit you need compressor.
Sep 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Stopped Working
if theres a circuit board look for a fuse that probably blew out.
Apr 23, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Refrigerators Logo
148 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
