Question about Boating
I have a 1981-1985 60hp Mariner 2 stroke motor. Need owner'should manual
How can i find the serial number on the motor.
Posted by Michael Chen on
Kardoc
    Top Expert:
  • Boating Master
  • 5,873 Answers
5 Related Answers
Carmen Mikulic
  • 415 Answers
SOURCE: free owners manual
hi there,
go to www.whirlpool.com
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
Posted on Sep 14, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: I am in need of an owner's manual for a SERIAL #: D34692693A
Here si the manual:
http://www.funai-corp.com/6pdf/om/MWD2206.pdf
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: 40 hp mariner outboard 2 stroke oil leak at
without seeing it in front of me its difficult to advise,i had a mercury but it wasnt oil injection so i iam not sure exactly how this injection system works but i should imagine its nothing more than a O ring thats perished or a copper washer needs cleaning with some wet and dry.I bought a new 4stroke mercury in the end because i got fed up with fuel consumption from the 80hp two stroke ,this four stroke 50hp will do about 12 14 nautical miles to roughly 6/7 litres of petrol at about 1200 rpm because iam only a sunday driver and the bumping on the waves makes my back ache unbearable,Well this is the land of fiesta /siesta /manaña --spain .Have a closer look and see where its leaking its only a mechanical pump running off the engine ,so it will have a push rod with some sort of diaphragm that pumps a tinysquirt of oil into the crankcase so it can mix with the incoming fuel ,nothing complicated
Posted on Sep 17, 2009
ray gallant
  • 68003 Answers
SOURCE: What year is 15 hp mariner motor serial number 684CSO47666,
http://www.autorepairmanuals.biz/site/573683/page/599222
Posted on May 17, 2010
I have a 1981-1985 60hp Mariner 2 stroke motor. Need owner's manual and how can I find the serial number and the year of the motoR? Which website can i search?
http://www.boats.net/parts/search/Merc2/Mariner/parts.html, searial is on the flat part near the out put shaft from the crank. usually covered in grease and dirt.
Feb 04, 2018 | Boating
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
75 horse power ercurywhat year of manufacture serial number 06255293
There is no data included in the serial number that gives info of what year the engine was made. You can, however look up the number here, and that will tell you the year of manufactor.
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 15, 2014 | Clymer Mercury/mariner 75-275 Hp...
Boating Logo
127 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
