Question about Freezers
SOURCE: Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Posted on Jan 02, 2009
SOURCE: portable ice maker not working as good as it did
Hi
Kindly refer to the Haier service manual which will help you for sure.
Thanks
Rylee
Posted on Jan 30, 2009
SOURCE: ice maker not making ice
either the thermostat is bad or the heater isnt working. You could take the icemaker out and connect leads to the heater to see if it warms up or use an ohm meter to test the heater and thermostat. Also take the cover off and see if the cog wheel on the motor is broken.
Posted on Apr 29, 2009
SOURCE: Blades in my Jenn Air ice maker are not turning.
There may be some ice buld up blocking the lever from turning. A blow drymay be a quick fix. I can't see in there so just guessing. Please leave a good thumbs up for the effort. The Raz Shack
Posted on Apr 21, 2010
SOURCE: the ice maker won't stop
Hi slh3095,
The easiest way to stop the ice maker in making ice is by raising the shut off arm.
Please check if the shut off arm can move freely.
Here are additional steps that you can apply to stop the ice production:
1. Raise the ice maker's shutoff arm until you hear a click and the arm stays in the up position. The ice maker will remain off until the shutoff arm is pushed down.
2. The shutoff arm is designed to automatically stop ice production when the ice bin is full. Using an ice bin other than the one designed for use with the refrigerator may not allow the shutoff arm to stop ice production.
3. Ensure that food packages, ice packs, etc. are not obstructing the wire shut off arm so it can move freely.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 01, 2011
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Sep 07, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Mar 20, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
590 people viewed this question
