Question about Power Acoustik Car Audio & Video
I need a picture of the circuit keyboard for 1600 watt Power Acoustik amp 4 channel
Posted by Terry Dorsett on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
Anonymous
  • 124 Answers
SOURCE: How big of am amp do i need?
Depending on what kind of music you listen to I would say around a 1200 Watt Amp would suffice for what you are saying. Thank you for using Fix Ya! Don't forget to rate the overall answer to your question.
Posted on Jan 28, 2009
Anonymous
SOURCE: 1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
Posted on May 13, 2009
Anonymous
  • 99 Answers
SOURCE: lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
Posted on Aug 03, 2009
Anonymous
  • 73 Answers
SOURCE: WHAT FUSE NEEDED FOR LA SOUND LAGUNA 100 WATTS BY
there are protection circuits also in solid state amps. so it may not be a fuse but a shorted relay, transformer, mosfet, etc. to test a fuse (once located) set a mulimeter to the audible chime continuity test mode. then simply place the red lead on one end and the black lead on the other. if it chimes it is good. if no chime it is toast. most amps use slo-blo fuses. i would guess a 250v 5amp. you just need to know the acutal size. usually the circuit board will be printed the right fuse to use. make sure you are not plugged into power!!! a good old school local hardware store should have a nice bulk/bins of fuses in the electrical dept. try not to use automotive fuses. look on ebay if you can and buy a bunch of them .
yostamplifier.com
Posted on Jan 21, 2010
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
How do i find how many ohms my amp is because i cant find it here the name of my amp is poweracustick lt 980-2 of 980 watt i want to know that so i know what speaker to hook up with
According to a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
Aug 09, 2011 | Power Acoustik LT-980/2 Car Audio...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Lt960-4 power acoustik Amp 4 channels mono
Aug 03, 2009 | Power Acoustik LT-980/2 Car Audio...
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp getting really hot
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Car Audio & Video Logo
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
