Question about Crate Music
What other amp uses the 06b885-20 effects board
I have a crate vtx350h amp head and my effects don,t work. were can i get a 06b885-20 board
Posted by Patrick Rowley on
3 Related Answers
Anonymous
  • 73 Answers
SOURCE: Distortion stoped working on my amp
Hi there. Sounds like the distortion foot switch is stuck. Try a shot of WD-40 where the button goes into the switch and then click it on and off a bunch of times.
Thanks
Paul
Posted on Jul 11, 2009
Fred Yearian
  • 5603 Answers
SOURCE: basically i cannot seem to
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
http://www.crateamps.com/pdf/manuals/FW120H_OM.pdf
Posted on Jan 11, 2011
guitarmanjoe
Joe Patch
  • 336 Answers
SOURCE: Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Posted on Mar 14, 2013
I need a crate 06b885-20 effects board. were can i get one
Guitar center used gear
zzzz sounds
reverb.com
sweet water.com
craigslist
Feb 04, 2018 | Crate Music
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp.
http://www.crateamps.com/support/index.php
Jan 28, 2014 | Crate CA30DG Taos Acoustic Guitar Amp, 30...
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Sound is shorting out...its not the cable that I am using I have no trouble with it in any other amp. The overdrive channel does not work at all. And randomly all the effects will just decide they want to...
It sounds like the DSP processor is either about to go out, or is mostly there. Have a qualified amplifier technician take a look at the DSP. Also look up the cost of a new one.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
I need schematics for this amp. know where I can get them?
Josh,
I also need schematics for this amp. How about whoever finds it first shares with the other?
Cool, Thanks,
bob at stumpweb.com
Jan 27, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
I have a crate GFX 50 and the effects come in only after about 15 minutes of play.
This is a warm up issue and can probably best be found by using circuit cooler on suspected components.
Other possible problems may be a bad solder joint or cracked circuit board.
Candle the board with a bright light to look for cracks.
Bad solder joints take experience to spot, but pay particular attention where panel mounted volume controls solder to the circuit board. Looking for the little ring around the solder menicus takes a sharp eye and good lighting. Resolder any suspected bad joints.
Jul 29, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
It will not work what colud be wrong
its a crate. 60% of all crate amplifiers go back on defects. take the top screws out and slide out the chasis, look at the fuse and determine if its toast. if the fuse is good, get a new amp. if the fuse is bad replace it and you should be good. the circuit board will have the correct fuse to be used printed on the board.
yostamplifier.com
Dec 30, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate tube amp will not power up but cooling fan tries to run
Yes.
Are you saying that the only indication that it is running at all is that the fans are running? So the tubes don't light up? No indicators on the front of the amp?
Power supplies that provide multiple voltages, which your amp has, can provide some of the voltages while having a problem that prevents them from providing others, all while not blowing a fuse. If you are not confident in your ability to work on a piece of electronic equipment that has 120VAC coming in and at least 175VDC or more present inside it, bring it to a service center.
The good news is that it is probably not horribly serious. Problems like this can almost always be repaired in a cost effective manner.
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
Music Logo
51 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
