Question about Sony Office Equipment & Supplies
My sony d300p dvd door is jam will not open
I just purchase and it was jam would like to fix
Posted by David Reckman on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Drive door jammed on emachines e4212
straighten out a paper clip and locate a small hole on the front of the drive, push the paperclip in the hold and the cd\dvd will come out. If might start working after this but chances are that if it does you will need a new one in teh near future.
Posted on Nov 19, 2008
stynger007
  • 33 Answers
SOURCE: jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
Posted on Aug 18, 2009
Don Matthews
  • 309 Answers
SOURCE: DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Posted on Nov 20, 2009
S. Gontko
  • 142 Answers
SOURCE: How do I program my remote for a sony DVD combo
Codes for Panasonic TV: 6, 19
Follow these steps to program the remote control to operate a television.
  1. Turn on the television to be programmed.
  2. On the remote control, move the TV/DVD VIDEO switch to TV.
  3. Press and hold the I/O button.
  4. While holding the I/O button, enter the television manufacturer code number using the number pad. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Release the I/O button.
  6. Point the remote control at the television.
  7. Press the POWER button to verify operation.
Posted on Mar 16, 2010
remaker
Phil
  • 449 Answers
SOURCE: sony dvd/vhs combo moldel#slv-d300p
You can grab a copy here:
http://www.avrd.cc/mc_files/2/SLVD300P_OwnerManual.pdf
Posted on Apr 24, 2011
Just received a Sony Receiver STR-K650 with a sony video DVD recorder SLV D300P WITH NO MANUEL OR INSTRUCTIONS ON HOW TO HOOKUP THE TWO SYSTEMS AND PLAY iT.NEED HELP?
STR-K650:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK650P&LOC=3#/manualsTab
SLV-D300P
http://esupport.sony.com/US/perl/model-home.pl?mdl=SLVD300P&LOC=3#/manualsTab
The above links will give you the instruction manuals and the connection guides.
Sep 07, 2011 | Sony STR-K650P
While trying to convert a VHS to a DVD, both are placed into the converter and I press the button indicating the process to begin conversion from the VHS tape to the DVD, but when I press the...
The Sony SLV-D300P is a DVD PLAYER and VCR. It does not record DVDs. You would have to buy a combo unit with a DVD recorder, not just a DVD player.
Mar 14, 2011 | Sony SLV-D300P DVD Player/VCR
When playing a CD the player will play the first 20 seconds of a song, then skip to the next song and then 20 seconds of that song, etc. I don't see any menu setting regarding any kind of skip feature,...
Tries it with other audio CD,if it have the same problems.Than the DVD player have a dirty laser eye scaner reader.Tries websites like Ebay.com,Amazon.com to buy a DVD player laser eye cleaner kit disc.
Dec 03, 2010 | Sony SLV-D300P DVD Player/VCR
Just purchased a used sony slv-d300p without a remote. Where can I purchase one
eBay.com offers many Remote Controls. Input the brand and model of your Sony Combo and your search will automatically produce separate Remote Controls along with separate listings for the Combo devices. These new or used Remotes typically range in price from $10-$20.
Good luck.
Oct 02, 2010 | Sony SLV-D300P DVD Player/VCR
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Nov 20, 2009 | Sony SLV-D350P DVD Player/VCR
WHY DON'T SONY RECORDABLE DVDS PLAY IN SONY DVD PLAYERS? I USE THE SAME PROGRAM TO BURN MEMOREX AND SONY DISCS, THE SAME DVD+R 120 MIN/4.7GB(OTHER THAN THE BRAND BEING DIFFERENT), AND i HAVE HAD NO PROBLEM...
all dvd recorders are very very sensitive when comes to which disc is fed to them......you say sony is the same as memorex is the speed the same 4x-16x, may i also suggest maxell, dynex and vertabram
Oct 23, 2009 | Sony SLV-D300P DVD Player/VCR
Dvd not closing
The tray for the dvd player runs along a track that is moved by gears. Something is obstructing the gears or motor that turns them thus your tray and door will not close all the way.
Best thing I can suggest is to buy a new one as having it repaired will not be worth the effort financially. Seeing as it is messed up you can play with it a little more in hopes it may get back on track and start working again.
Note: from personal experience the more you try and force it the worse the problem will become (Burn out the motor, damage the gears further).
Thank you for choosing Fixya!
May 19, 2009 | Sony SLV-D300P DVD Player/VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Playing jpg
This is due to compression of the file. Big, highly compressed jpegs are hard to open on this kind of device.
Aug 02, 2007 | Sony SLV-D300P DVD Player/VCR
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
