Question about Whirlpool Washing Machines
Cleaned blockage and all pipes and suds from F02 and SUD. Ran Diagnostic. Sticks at C05. Why replace a working pump?? or is there a "Reset Code" F02 code to put the unit back in working order?
Whirlpool GH9400PW0
Posted by Cary Lawrynowicz on
5 Related Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: GHW9150PW0 Whirlpool Duet washer will not spin F02 and Sud
There is a sensor that relays information back to control board. If you have new pump, pressure switch and latch, the sensor is most likely faulty
Posted on Jun 30, 2009
Anonymous
  • 999 Answers
SOURCE: ''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Posted on Sep 18, 2009
Anonymous
SOURCE: whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Posted on Jan 22, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: my front load whirlpool washer keeps saying sud
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Posted on Oct 25, 2010
Testimonial: "Thanks for your help,I thank my pump is bad."
Czerney Dort
  • 170 Answers
SOURCE: SUD Code appears on Whirlpool
sud means over suds are you useing he soap maybe too much.......
Posted on Mar 24, 2011
Why is it displaying SUD and F02?
remove the top of the unit and inside is the trouble code paper work that will guide you to anything that is wrong.
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
Hello...my Whilpool Duet washer keeps giving a SUD and F02 error. Now...this just happened a couple months ago and we replaced the Drain Pump Assembly...is it possible that we are once again going to have...
Hello, W/D here.
What you are seeing is the suds (SUD) error code, followed by a long drain fault code (F02).
This does not necessarily indicate that you need to change anything at this time. When the machine senses too much suds, the error code is displayed, when too much suds are actually present, a longer drain time results.
Duets are HE (high efficiency) machines, and require a detergent that produces little suds. If you are using HE detergent, cut back on it until you can run a cycle without getting the SUD/F02 alarms. If you are not using HE detergent (we don't either), you really have to be careful with the amount of detergent used.
Press PAUSE/CANCEL twice to clear the display. Run a cycle without any detergent to flush the machine.
It is advisable to check that the drain hose isn't plugged or have a kink in it.
Make sure that the pump is running. You may need to check the electrical connections at the pump.
You might check the filter on the drain pump for debris or foreign objects, which might cause the drain cycle to be extended.
If limiting the detergent, and nothing was found in checking the other items listed, then the pump may need to be replaced.
Best regards, --W/D--
Please help us by rating our solutions. Thanks.
1helpful
Whirlpool duet washer GHW9150PW will not drain.
1helpful
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
1helpful
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
5answers
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
135helpful
8answers
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Open Questions:
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
