Question about Nintendo Video Game Consoles & Games
How do you set up the nintendo slack
Tell me how to set up the nintendo slack
How to set the tension correctly
Your manual should tell you what number your tension should be at, but ii always just pul the thread manually an if it glides through machine a wee sample check you bottom stitch if it's slack , tighten the tension, if it's tight slacken tension
Aug 13, 2014 | Sewing Machines
Jinlun 125-11
This post contains only PC desktop Post it in the correct platform
Mar 15, 2014 | Computers & Internet
I'm trying to connect to my wifi so I can play poke on soul silver online but when I search for an access point it tells me "the access point's security settings are not supported by the...
Nintendo WFC is only compatible with the WEP security setting, even when playing with a Nintendo DSi or Nintendo DSi XL. WPA and other security settings are not compatible.
solution: You will need to either change your security settings on your router to "WEP" (recommended), or disable all security.
for help with this: http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
Jul 25, 2011 | Nintendo DS Lite Console
My internet says the access point's security settings are not supported by the nintendo ds. for help visit support.nintendo.com. that is what it says.
Hi weigels,
I see you are getting an error security settigns not support by your Nintendo DS.
I beieve that you are trying to access a wireless connection using your Nintendo DS, the error that you are getting is actually an error saying that your Nintendo DS can detect the router but since your Router has a Network key you then get the error security settings not supported.
for a Nintendo DS it does not support Router settings that have a network security on it, you will have to disable the Routers Network security for you Nintendo DS to be able to access the wireless network of your Router, this will also prevent your Nintendo DS from getting the error security setting not supported.
Note: disabling your Network security will open your Routers signal to anyone who can detect the signal.
I hope this helps.
Have a nice day,
mvincentc
May 09, 2011 | Video Game Consoles & Games
Im trying to get wi-fi connection on it and its telling me that "The access points security settings are not supported by the nintendo ds'
That means that the connection you're trying to connect to is probably a WEP-encrypted WiFi source. The Nintendo DS Lite cannot support that format of WiFi, however Nintendo has posted a very detailed and visual step-by-step guide in how to resolve that here
Just scroll down to "My security settings are not supported or are not compatible" and follow the instructions.
Good luck.
Apr 03, 2011 | Nintendo DS Lite Console
I'm trying to play the new Pokemon Black but I want the free promotional Victini and it says I gotta have Wifi and I'm like "Ok..." And I try to connect it to my houses Wifi but this comes up!...
Hey darthbunnyva!
The reason you need a wi-fi to redeem your pokemon is for Nintendo to be able tu check that every code is unique and people are not cheating the system and getting the pokemons they don't own.
To set up your Nintendo DS for online use just follow these official nintendo guides for configuring your wi-fi
http://www.nintendo.com/consumer/wfc/en_na/ds/index.jsp
Hope this helped!
-Luchen
Mar 07, 2011 | Nintendo Video Game Consoles & Games
Chane slack
Slacken the wheel nut a couple of turns ,then simply adjust tension with the chain adjusters at the rear of the swingarm legs. Look carefully you will see notches marked on both sides of the swingarm by the wheel spindle these must be the same on both sides, your manual will tell you the chain slack for your bike.probably about 25-35mm put a ruler up to the chain and using finger pressure push up on the chain ,this is the chain slack. Once done tighten the wheel nut up to correct torque setting.( manual or call local dealer),then replace split pin with new through the wheel nut. Double check all your work no loose nuts,then sit on the bike get a friend to wiggle the chain there should be small slack as first meashured 25-35mm again, if not re-try,once experienced you will do it first time.
Mar 04, 2010 | 2000 Honda VFR 800
It wont connect to my internt it says that its security setting are not supported by the nitendo ds and then tells me to go here for help game: club penguin
-Taken from Nintendo Support-
If your network name (SSID) is displayed on the Nintendo DS with a gray locked icon (pictured below), then your router is set up with security that is not supported by the Nintendo WFC. Playing multiplayer over the Nintendo WFC is only compatible with the WEP security setting, even when playing with a Nintendo DSi. WPA and other security settings are not compatible. yourssid.gif Solution:
You will need to either change your security settings on your router to "WEP" (recommended), or disable all security. For information on changing the security settings of your router, click here.
Oct 18, 2009 | Video Game Consoles & Games
NINTENDO DS
Simply ring Nintendo Customer Service
(03) 9730 9822 MONDAY TO FRIDAY 9:00AM TO 5:00PM (EST)
they are the people to deal with warranty, EB sometimes are very slack and you'd be better off going straight to nintendo australia.
Feb 14, 2008 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
