Question about Locks & Locksmithing
SOURCE: ignition
ther is a linkage between the key switch and the ignition switch that is under the dash on the steering column. it is called an accuator. i have been driving fords a long time and i have changed five of them since 1980 when ford put the switch on the column. you will have to start off by removing the steering wheel then yhe ignition switch and so on. it is tricky... but not bad..
Posted on Jun 17, 2008
SOURCE: Just installed kwikset 909 all
For your review, here is a link to the installation instructions for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Under the Troubleshooting steps at the bottom, you will see this text:
Q: I just completed the installation of a Smart Code unit on my door; I am unable to operate it manually, although I checked for smooth bolt operation during installation. What should I do?
A: You need to run the "Bolt Direction" routine again; allow the process to run to completion see Section 8 in User's Manual.
So please go through the installation instruction's Section 8 again. (Remove the battery pack first.) It is important to follow this procedure very carefully for success!
If you feel that you are following all steps correctly but the lock is still not functioning properly, please contact the Kwikset Customer Support:
Call: 1-800-327-LOCK (5625)
Posted on Jul 20, 2011
Jul 20, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
May 27, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Apr 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Mar 03, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Feb 07, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Dec 16, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Oct 18, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Aug 07, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Mar 16, 2010 | 1990 Ford F150
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
205 people viewed this question
