Question about Samsung Televison & Video
Samsung UN65JS9500FXZA, No picture, but audio.
Replaced main board, power supply, LED driver board and TCON board. All OEM replacements. Still have no picture, But have audio. Cannot access menu. Picture is completely black.
Posted by Scott Mrzywka on
rostit
  • Samsung Master
  • 737 Answers
Sounds like a bad panel. Did you do a short check for the driver ics on the flat flex?
Posted on Feb 02, 2018
Testimonial: "I found a loose flat cable to the TCON. I now have a blue pic with LED, but no access to the menu."
5 Related Answers
Lawrence Oravetz
  • 10543 Answers
SOURCE: Have Samsung led replaced Tcon board now have dark screen and vert-horizontal lines no picture but have sound
Check both ends of the ribbon cables for proper seating. Also make sure you didn't cross them up. You will melt a trace if you did.
Posted on Sep 27, 2015
gopakumarg43
  • 76376 Answers
SOURCE: Model e550i-b2. Backlight comes on but why no picture?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If you wish to get assistance over phone, visit this site. https://www.6ya.com/
Posted on Nov 02, 2015
gopakumarg43
  • 76376 Answers
SOURCE: sound but no picture i've replaced led driver , Tcon board and power supply board still no fix
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Posted on Apr 03, 2016
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: Led no picture
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Posted on Jun 10, 2016
Derrick Gee
  • 3 Answers
SOURCE: Vizio E550i-b2 TV has no backlight, pic or sound. Replaced power and Main boards - still having the problem. Any suggestions? I have the TCON and LED Driver board left
The led is what makes the picture try replacing that it it's the only one you didn't change out
Posted on Aug 31, 2016
Have Vizio E60-c3 LED TV. Picture not working, Backlights on, Audio works. Ordered Complete repair kit from Shop Jimmy.
About 99% of the boards from shipjimmy are good, unfortunately lI think you have a bad panel and its destroying the tcon board, did you check the fuse on the tcon board?
Feb 21, 2018 | Vizio Televison & Video
Can you help me troubleshoot my TV? It has audio but no picture.
Use a voltmeter to confirm all the voltages are present when the TV is powered on. If they are all correct then replace the led driver.
Jan 13, 2018 | Samsung Televison & Video
The backlights aren't working on my Samsung UN32ES6500FXZA TV. I performed the flashlight test and can see a picture and the audio works. Can you please let me know what part needs to be replaced?
You have at least one shorted LED in the panel, reason it works with the main disconnected is your removing shutdown circuitry, don't run it this way for any longer than necessary when looking for the faulty lamps..Also be really gentle with the panel and flat cables going to the TCON board, they can be damaged quite easily and if that happens the set is junk..good luck!!
Nov 15, 2017 | Samsung Televison & Video
My samsung led tv, when i turn on red light blinks 6 times. no display, no sound. Tried replacing power board, main board and tcon board, all of them seems to be fine. What else could be the problem.
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
Oct 26, 2017 | Samsung Televison & Video
Samsung SUHD UN65JS9500FXZA. The screen is black but also you can barely see a picture of you're up close. With the screen black there is good sound. Is this a tcon board issue?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 21, 2017 | Samsung Televison & Video
LED TV, DSE GE6880 TV flashes when power on; no picture, with audio. No backlights, has picture with flashlight test Have tested LEDs - all working Infrequently TV turns on and works no problem!
Jan 13, 2017 | Televison & Video
I replaced the t con board and the main board in my Samsung led tv and I still do not have a picture
Hi Tony,
If the backlight is there and still there is no picture, what is left is the main board. But before that please see that the Tcon board is receiving necessary voltage from the main board. Please also check the power supply board for producing all the necessary voltages.
Good Luck.
Apr 29, 2016 | Samsung Televison & Video
I have a samsung 46inch led tv ( UA46H7000AR) i have problem with no backlight but audio is working what is the exact issue. does it concerned with led backliht srips or tcon board
Apr 18, 2016 | Samsung Televison & Video
Televison & Video Logo
240 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
