Defy make all types of appliances in South Africa, washers (the category you posted to), dryers, fitted wall ovens and cooking hobs. The secret to providing you with a good answer is full
'make model [number] (what it is)'.
If it is a Defy cooktop, take a look at this answer from me last November 2022.
The error code AF30 on a Defy slimline stove top typically indicates an issue with the stove's touch controls. Here are a few steps you can take to try and fix it:
Turn off the stove top at the circuit breaker for a few minutes and then turn it back on. This can sometimes reset the touch controls and clear the error code.
Check if any of the touch controls are stuck or unresponsive. If this is the case, try gently cleaning the area around the touch controls with a damp cloth.
If the above steps do not work, you may need to replace the touch controls. This is a more complex repair and may require the assistance of a professional technician.
If the problem persists, it's best to contact a qualified technician to diagnose and fix the issue.
The error can occur if a pan or utensil is left on the control pad while the cooktop is unlocked. Remove the utensil or pan. If these troubleshooting steps do not resolve the issue, service is necessary to expertly diagnose and repair the product.
Error code 22 on a Defy Slimline hob usually indicates an issue with the touch control panel or power supply. Here are a few steps you can try to resolve the issue:
Turn off the power to the hob at the circuit breaker for a few minutes, and then turn it back on. This can reset the electronics in the hob and clear the error.
Check the hob's power supply. Make sure the hob is getting power from the electrical outlet or circuit breaker. If the hob is plugged in, try plugging it into a different outlet or resetting the circuit breaker.
Check the touch control panel. Sometimes, the error code can be caused by a problem with the touch control panel. Make sure the panel is clean and free of debris or moisture. If the panel is damaged, it may need to be replaced.
Contact a qualified technician. If the above steps don't resolve the issue, it may be a more serious problem with the hob's electronics or power supply. Contact a qualified technician or the manufacturer for further assistance.
