Question about American Standard Home
My American Standard # 3378513.020 does not flush. It seems to not have the pressure. It takes about 3 times to get it to flush which defeats the purpose. How do I fix this?
Posted by Anne Fotheringham on
brian williams
    Genius:
  • 1,864 Answers
Possible blocked vent.
Posted on Feb 01, 2018
Joe Ball
    Master:
  • 589 Answers
First, make sure the water feed to the tank is wide open, then make sure you have the inner workings set at maximum water level.
5 Related Answers
Anonymous
SOURCE: american standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Posted on Nov 23, 2008
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
jpintore
  • 129 Answers
SOURCE: My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Posted on Sep 28, 2009
American Standard Edgewater Single handle pull out faucet. Hot water pressure trickles.
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
Sep 23, 2018 | American Standard Plumbing
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
My American Standard R120 shower valve has excellent pressure on the cold side, no pressure on the hot side.
Could be a chunk of scale in the valve. Need to turn off water supply and take valve apart. If nothing is found, turn water supply on to give line a 'quick' flush and turn back off. If this does not help, you probably have an obstruction somewhere in the hot supply line and a plumber may be needed unless you are handy. Good luck.
Jan 01, 2014 | American Standard Home
Toilet flushes 3 times when it is flushed.
take off top cover, and check flapper valve for proper seating when flushing.. could be that it is dirty (where it makes contact with tube of tank), and/or the chain length is too short (one link or two)
May 25, 2010 | American Standard 2002.014 - Champion4...
I just installed an american standard cadet 3.Home depot rated this toilet as a 10 for flush power. when I flush 1st off the flapper wont stay up on it own long enough to flush,2nd if I hold it open it is...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
Like you said, Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot also sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps.
r/
David
Feb 24, 2010 | American Standard Cadet 3 Round Toilet...
Sep 27, 2009 | Home
Cadet 3 round bowl toilet not flushing all from bowl
May 08, 2009 | American Standard Cadet 3 Right Height...
American standard toilet
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
53 people viewed this question
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
