Question about AT&T Computers & Internet
How can i fix AT&T Email Error Code 475 ? - AT&T Computers & Internet
Posted by Email Support Number... on
DocZachary
    Master:
  • AT&T Master
  • 533 Answers
It appears if you have web links to other sites in your email signature, Yahoo Mail will flag it.
https://answers.yahoo.com/question/index?qid=20131105093109AAR5Kbv
Also, if you log in from a location different from the one you normally use, especially if it's outside your home country, or if you recently changed ISP providers, that can trigger it as well.
https://answers.yahoo.com/question/index?qid=20130803075759AAlzX7O
A third possibility is that your username and password have been compromised, and someone else is logging in and using the account to send spam.
Yahoo/ATT has very good customer support. Chat/Call them and they can help you solve the problem.
Semper Fi,
Z
Posted on Feb 01, 2018
Testimonial: "When AT&T Email Error Code 475 appears on the screen of your system, then you would receive a Mailer-DAEMON message that reads as Sorry, we are unable to deliver your message to the following address (email address). : Error Code 475: Suspicious activity was detected on your account. Consequently, you get unable to send messages to the email recipients after the occurrence of this error. Hence, AT&T email services stop supporting your devices. This problem may exist for a long time if it is not getting fixed immediately. In this blog, we are discussing the roots of this technical issue as well as the symptoms. We will also share some important steps to fix this error without concerning technical help or call us 1-888-909-0535"
yustina wilson
    Sergeant:
  • 224 Answers
Need to fix yahoo error 475 so just make a call on Yahoo customer service number 1-888-587-9269 anytime and experts are there to help you 24*7. Customers may call on Yahoo support 1888-587-9269 anytime and experts will help you to fix issues 24*7.
http://www.allsupportno.com/how-to-fix-yahoo-mail-error-code-475
Posted on Mar 30, 2020
How do I fix 'error 10060' in my Outlook mail account?
How to Fix the Socket Error 10060 Home > Outlook > How to Fix the Socket Error 10060
PC Support Hotline: 1-844-377-4107 DOWNLOAD
Certified safe, virus free download. Error Tools Editor's Choice. Error Causes
The cause of this error code is hard to narrow down typically because there are many causes that can trigger the socket error code 10060. Some of the most common causes of this error code are:
  • Issues in email settings
  • Authentication settings
  • Firewall settings
  • Malware
Though this is not a critical error code but it is advisable to fix it immediately without any delays.
This error can hamper your communication via email and slow down your work productivity especially if you use Outlook for communication across the organization. Further Information and Manual Repair
Here are some of the many methods to fix and resolve this error code. To help you resolve this issue, we have selected and listed down the best, quick and easy do it yourself methods. Try them and repair Socket error code 10060 all by yourself without any professional assistance.
Method 1 - Check the Names of POP3 and SMTP Servers
To begin with, first check the names of the POP3 and SMTP servers to ensure that they are correct. Then check the outgoing SMTP port. Contact your email provider to determine the correct settings.
Sometimes email providers change this value more than any other in their individual settings. Get it verified. Change the settings if needed.
Method 2 - Outgoing SMTP Server Requires Authentication
Sometimes the error code may occur due to authentication issues. If this is the reason then, don't worry it is easy to fix. Simply go to the settings options and check the box 'My server requires authentication'.
Once you check the box, try sending the email again. This is most likely to resolve the socket error 10060 on your PC.
Method 3 - Disable Firewall
Your Firewall security may sometimes be the reason for socket error 10060 too. Therefore if after trying method 1 and 2, the error still persists, then it is advisable to disable firewall.
Once you disable it, try sending an email using your Outlook account. If it works, the error is resolved.
Method 4 - Scan for Malware
There is a possibility that the Socket error 10060 is popping on your PC due to malware infection. If so, then it is advisable to download Total System Care.
This is a highly functional and a user-friendly PC fixer deployed with a powerful antivirus and several other scanners. Run it on your PC to scan for malware. It detects and removes all types of malware including Trojans, viruses, adware, spyware and more in seconds.
Dec 27, 2017 | Computers & Internet
What does heater code "EO5" mean?
stack flue sensor error its an easy fix try the sensor first what this does is monitor the exhaust temp if it get above 475 it shuts down if it does not get above 25 it shuts down, the sensor is usualy bad but blockage in the combustion chamber will affect exhaust temp
Jul 21, 2014 | Pentair Master Temp Pool and Spa Heater...
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
475 Hart not boot properly
It is not possible to boot.
The unit did not boot up properly
Mar 20, 2014 | Yokogawa Emerson 475 Hart Communicator
475 Communicator does not Boot Up
I have the same problem... how can I fix it?
Jul 24, 2013 | Yokogawa Emerson 475 Hart Communicator
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at [email protected] thank you.
Oct 21, 2012 | Canon imagePROGRAF iPF8000 Printer
CAN'T GET MY YAHOO EMAIL MESSAGE TO LOAD' MY ACCOUNT ERROR 5
First, try pressing ctrl+F5. Attempt to load it in another browser.
1.When you try to access an email message that has been moved or deleted. For example,
if you delete an email from your inbox and hit the back button on your browser, the email
will still show up in your inbox. Even though it looks like the email is there, it really isnt!
2. If you clicked on a legitimate email message that wasn't deleted or moved and you get
an Error Code every time, click Check Mail and then try to access the same email again.
3. You have several windows or tabs open in the same Yahoo! Mail account. The Error
Code
is a temporary problem which should go away once you close the additional tabs
or windows.
4. You're running the browser-based Yahoo! Mail service, and another mail service (such
as Outlook or your mobile phone email service) tried to access your Yahoo! Mail server.
Try shutting down your other email services to see if this removes the Error Code.
5. If that didn`t help try Yahoo Customer Service to fix the error.
Contact Customer Care (reply needed)
Is your Mail not working right? Need help finding or doing something?
http://help.yahoo.com/l/us/yahoo/mail/ya...
Mar 15, 2011 | Yahoo Mail
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Open Questions:
Computers & Internet Logo
214 people viewed this question
Top AT&T Computers & Internet Experts
Vincent G
Vincent G
k24674
Jax Planet
Jax Planet
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
