Question about Sony Office Equipment & Supplies
Sony Data Projector VPL-EX7 green light on for seconds and automatically when off. The on/off key indicates red light 4 times and scan for few seconds. What might be the problem, what shall i do?
Posted by Philip Ajuong Deng on
5 Related Answers
Anonymous
SOURCE: SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Posted on Apr 10, 2008
Anonymous
SOURCE: Sony VPL-CX6 lens protector not opening
Your lap its not working , mabe is over 2000 hours , you need a new one.
Posted on Jun 30, 2009
Anonymous
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
omtronixom
om sharma
  • 172 Answers
SOURCE: Our Sony VPL-EX4 Projector keeps shutting itself
Check fan cable
Posted on Aug 11, 2010
Anonymous
  • 55 Answers
SOURCE: SONY VPL FX-40 projector. After plug
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Posted on Feb 19, 2011
Sony VPL-ES7 projector boots up after few seconds switches off, with a red light flashing severally on the power button. Please what could be the problem because i have serviced the projector!!!!
Check the fan connections, one might not be connected right if you have just serviced it. Switching off with a flashing red light usually indicates a fan error.
Also is there a sequence to the flashes? e.g, 4 flashes and pause?
some manufacturers have a fault code table for the amount of flashes.
Nov 09, 2016 | Sony VPL-ES7 LCD Projector
Lamp is not working
How many times is the red light flashing at one time? The flashing is an error code, the number of flashes indicated the problem. It could be the bulb, the fan, a power issue, or even your altitude.
Mar 02, 2014 | Sony VPL-EX100 3LCD Projector VPLEX100
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
Feb 19, 2011 | Sony VPL-FX40 Projector
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Mar 18, 2009 | Sony VPL-CX6 Multimedia Projector
66 people viewed this question
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
