Would like to bypass lid lock so I can see agitation
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
SOURCE: Washer fills and agitates but
Hello there and thank you for choosing fixya
OK first lets get back to the basics
First investigate these things fully
It doesn't drain
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
3. TIMER OR CYCLE SELECTOR
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer.
THERE IS NO REPAIR FOR THE TIMER
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken.
If you are under warranty get it replaced. If not remove the top of the washer
and take out the switch assembly. The 4 wires going in are Yellow, Red, White,
and Blue. If you short the white and blue together, the washer thinks the lid
is closed. If you short the red white and blue together the washer thinks the
lid is closed and locked. The yellow is only there to activate the
electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter
of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if
you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
