Question about Casio Office Equipment & Supplies
Here is a user guide that should prove beneficial.
I hope it helps.
http://support.casio.com/en/manual/004/fx-300ES_PLUS_EN.pdf
Posted on Feb 01, 2018
SOURCE: Adding Exponents on a Casio fx-300MS
The calculator applies the rules during the internal calculations. But all it shows you is the (final) result. It does not keep track of what exponents you used to get to the result. It is not capable of doing symbolic manipulations.
Hope you are not too disappointed.
Posted on Sep 25, 2009
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Posted on Dec 03, 2009
SOURCE: How to use the exponent key on a casio fx 300ES
The key to use for the square, and the cube are well marked and they share the same physical key (X to 2) or [SHIFT][X to 2]. Similarly the keys to use for the square root and the cube root share the same physical location (the square root key, to the right of the square key).
For any other exponent, including fractions and negative exponents you use the universal power key labeled [X to ] ( X with a raised square).
Sometimes the result may not be displayed as a decimal number, but as a radical (if you take a root). To make sure it is displayed as a decimal number, in step 4 above, press [SHIFT][=]
Posted on Mar 13, 2010
SOURCE: where is the exponent button on this calculator
It is the [xy] key.
I hope this helps.
There is a guide online at this LINK.
If you could, please rate this post.
Posted on Mar 22, 2010
SOURCE: how do i solve Exponential
Click here to download the Casino FX-300 training guide .
Posted on Feb 06, 2011
Sep 08, 2014 | Casio fx-115ES Plus Scientific Calculator
on Jan 17, 2009 | Casio FX-115W Plus Calculator
Jan 19, 2014 | Casio fx-115ES Plus Scientific Calculator
Feb 10, 2013 | HP Casio FX-300 Plus Scientific Calculator...
Jul 30, 2011 | Casio fx-300ES Calculator
Jul 26, 2011 | Casio FX-9750GPlus Calculator
Oct 27, 2010 | Casio FX-115ES Scientific Calculator
Mar 13, 2010 | Casio FX-300W Plus Calculator
Apr 07, 2009 | Casio FX-115MS Plus Calculator
Mar 24, 2009 | Casio FX-300W Plus Calculator
733 people viewed this question
