Computers & Internet Logo
Patience Posted on Feb 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone have access to a Southbend - Model 4365D - Serial #10H08077 - Oven Manual? Apparently, it may need a new thermostat and gas valve. Thank you in advance!
Circa 2009
  • Anonymous Oct 03, 2018
    Customer riteaid survey
    storesurvey.riteaid.com
    survey is also one of the main advantages to ensure the growth and success of the company.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Feb 02, 2018
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689375
Points
8444
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Feb 11, 2007
SOURCE: leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
Anonymous
  • 331 Answers
  • Posted on Oct 11, 2007
SOURCE: new gas valve, new gas smell
CG, unfortunately you replaced the wrong part. The problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating. It will also cause your symptoms as well...
Here's the scenario; Say your safety valve is "looking" for 2.5 amps of electricity flowing through it before it'll open up and allow gas to the manifold. Your igniter is designed to allow 2.8-3.2 amps to flow in good operating condition, but your igniter has become "weak"... it's now allowing 2.48-2.51 amps. The safety valve is sensing this and opening and closing rapidly, allowing gas to flow through it (fluttering). BUT! the igniter is not hot enough to ignite the gas and/or there is not enough gas to ignite do to the fluttering effect of the valve. Sometimes it'll light sometimes it won't.
Your igniter is the cause and needs to be replaced.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Anonymous
  • 13 Answers
  • Posted on Nov 30, 2008
SOURCE: gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Mar 27, 2009
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Anonymous
  • 7 Answers
  • Posted on Jun 01, 2009
SOURCE: Thermostat + User Manual
Stoves are still there you can contact them on 08712222502
Southbend 460DD-2TR no pilot after replacing safety valve/thermo couple
Sounds like if you are not getting any kind of flame your pilot assembly will have to be taken out and cleaned. Your pilot orifice is clogged up with build up. Will need a screwdriver, 7/16 wrech and or a 1/2''.
I need to calibrate my southbend model #x436d standard gas oven
If you pull the knob off there is a very little screw in there that you can turn with a small screwdriver. I believe left is increase and right is decrease, but I could be wrong. Very little turns do a lot. You can tell if you are going the right way if the burners get bigger or not. This takes a while so do a 1/4 turn and let it sit for a while, take temp and adjust again if needed.
The gas orfices were changed to propane from natural gas. What size of gas orfices does this oven require? Or will any licensed gas fitter know this and have them on hand to convert this oven back to...
Sorry to read about your problem, I hope this helps you out.
you will have to contact southbend for that info..it is not a common practice to convert these units.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
Natural Gas, convection oven won't heat. New flame sensor installed, 1/13/10, digital timer and temperature work heat light is on but unit will not fire up, hot surface igniter works fine. Gas valve??
If the gas valve is on(no continuity) then yeah that is it, keep in mind the ignitor could be weak. I didn't notice where you replaced the ignitor and you say it is working so that means the gas valve has continuity. You need 37 ohms on that ignitor or a total amp draw of at least 3.5 to open that valve.I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Trying to find Thermostat on the for the top oven not heating up
Call Rick at Restaurant Parts and More. 1-888-814-1110.
Be sure to have model and serial numbers to get the correct part.
Hope this helps.
Hello, I have a Soutbend cooker serial N° NX
Be sure to have model and serial numbers to ensure the correct part.
1helpful
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 • Ovens
Do we need an exhaust flue for a southbend half size gas oven?
Depending on your local code, you will need an exhaust hood due to the byproducts of the gas burning. Some locals allow for electric ovens to go without hood. Gas units generally require a hood system with proper fire suppression equipment. You may want to check with your local fire and building inspectors.
2answers
Want a manual for my oven
google your model # youl see lots of links
Grand Canyon Tech
Grand Canyon Tech
