The lights all come on when powered up but the chair does not move, rather the service light flashes orange seven times
SOURCE: i have an invacare pronto
Leet you have a left motor problem. Usually the motor has to be replaced Sorry Hope this helps
SOURCE: wwe have a pronto m41 mobility chair.the service
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
SOURCE: What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
