Question about The Computers & Internet
Name of an experienced tech for the Bernina 1630 in the Winston Salem or Greensboro, NC area
Computer board wont come on
Posted by Patti Nichols on
DROPNDEAL
    Top Expert:
  • The Master
  • 2,931 Answers
No one is going to advertise a persons name on an online self-help site.
Contact your local retailer directly or online here:
https://berninaofamerica.zendesk.com/hc/en-us
Posted on Jan 31, 2018
4 Related Answers
Anonymous
SOURCE: portable dvd player Lennoxx 702
i guess you can try radioshack.
Posted on Oct 22, 2008
Jason Stephenitch
  • 254 Answers
SOURCE: Oven does not work: pilot light out? How
Actually, your oven probably doesn't have a pilot light at all. In order to ignite the oven, it has an oven igniter. If you open the broiler, look up on the "ceiling" of the broiler to the back of the burner. There, you'll see a white block. That is the igniter. What it's supposed to do is heat up (electrically) and when it heats up enough, the gas valve turns on and the oven lights. What happens with these, is that the heating element on it opens from years of use and must be replaced. Inside the broiler door (usually) is the stove's model and serial numbers. Write them down and visit your local appliance parts store with those numbers and they'll give you a new one. (Usually around $30-$45 or so.) Also, you can usually change the igniter from inside the oven by removing the bottom drip plate, so that'll save your back a lot of straining. :)
I hope this helps and hope you have a wonderful holiday season!
-Jason
Posted on Dec 22, 2010
Michael Lindsey
  • 70 Answers
SOURCE: Can you send/mail me an
LOL it would be helpful if you provided us with the Phone make and model that you would like the instructions for lol/!!!!!!!!!
Posted on Dec 25, 2010
ANTHONY HUDSON
  • 461 Answers
SOURCE: Best place to have keys
HOME DEPOT YOUR AT LOCK SMITH COMPANY
Posted on Mar 13, 2011
Cruise control wont engague
The speed control system is controlled through the main on board computer called the PCM, in order to determine the cause you must have the system scanned for fault codes. soooo.. off to the dealer.
Jul 27, 2012 | 2007 Chrysler 300C
My fan wont shut off
your pc mother board problem please check mother board *********** board capster is week and change week capster
May 07, 2012 | Dell Inspiron 530 Desktop Computer
Computer treadmill wont work
Causes:
1) Blown fuse or breaker check it.
2) VSD/MICROPROCESSOR(cOMPUTER)/EPROM/SRAM Failure
3) Check connectors loose to display board, or corroded contact from connector to display board.
4) Missing +12VDC to display board.check power supply +tansformer.
E.CUADRA
Oct 09, 2011 | York Barbell Home Use Fold-Up Treadmill
I want a new video card for my computer wondering if it will be a waste bc my computer was super cheap
I would invest in a more powerful machine to get the most value for my money. I found some very nice computers online at Amazon and at "The Computer Store".
Apr 01, 2011 | eMachines EL1352G-01w (884483537679) PC...
Compressor is off and will not come on, how do you turn the compressor on
It has freon in it? If yes, you need to reset the low freon shut down. To do this just unhook the battery for a couple of minutes.
May 31, 2009 | 1997 Cadillac DeVille
Blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
May 04, 2009 | Heating & Cooling
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
