Stasiki Markov Posted on Jan 31, 2018
NEC projector parts cooling/ rolling pump nec mp60?
5 Related Answers
Anonymous
  • 115 Answers
  • Posted on Feb 07, 2008
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Anonymous
  • Posted on May 18, 2008
SOURCE: Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
Anonymous
  • 726 Answers
  • Posted on Sep 13, 2008
SOURCE: nec gt5000 projector turns off 10 seconds after power up
that is usally cause of the lamp this is not in my expertise but that happened to my dads one if the lamp is at the end it will shut down it usually give warnings first like change lamp then its over has to be replaced
Anonymous
  • 4 Answers
  • Posted on Nov 22, 2008
SOURCE: NEC vt440 projector is overheating
Try cleaning the filters, there is one on the front and one on the side. When dust builds up on these it can restrict the cooling of the projector
Anonymous
  • Posted on Aug 26, 2009
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Where can I buy a new filter for a NEC VT465 projector
Contact the authorized service center for NEC. If you know the part number to it (refer its repair manual), you can buy it online from www.alibaba.com/
Electro help
My nec mp400 projector keeps turning off every 2 minutes when started up
Check its cooling fans for proper ventilation. If you wish to get more details, check this link.
What is the purpose of the coolong pump? What sort malfunction could occur due to that?
This system uses a cooling pump, to pump high pressure / high velocity air around the lamp dramatically improving cooling efficiency.
With this new cooling system, the body can be further reduced in size compared with ordinary projectors that use a single cooling fan.
If the cooling pump fails then the lamp will overheat and shut down
1helpful
Nec lt20 how to repair "cooling fan not operating"
you'll need to replace the fan. however, nec does not sell parts. you'll need to send it in to them. unless you remove the fan and, using the part number on the fan, search the internet for a replacement. try digikey.
5helpful
Blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
3helpful
2answers
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
6helpful
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
1helpful
Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here: http://safemanuals.com/user-guide-instructions-owner-manual/NEC/MT600
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from www.partstore.com
1helpful
2answers
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
