Question about Ford Garden
Does my 600 ford tractor mo#640 seral#70231 have A 9inch or 10 inch clutch.
Posted by Charles brannon on
obsteiner
  • Ford Master
  • 901 Answers
This says 9" -
Posted on Jan 31, 2018
Testimonial: "Thanks for the info. It was very useville"
1 Related Answer
obsteiner
  • 901 Answers
SOURCE: Does my 600 ford tractor mo# 640 seral#7o231 have A single or double clutch.
This says the double disc clutch isn't an option til the 660 series.
Yesterday Tractors Tractor Profile Ford 600 Series
Posted on Jan 29, 2018
I have a ford tractor with the model number 640 and serial number 11377 can you tell me any history about this tractor
Yours was made in 1955. If you go to www.yesterdaystractors.com you can see most of the original spec and history
Aug 15, 2016 | Ford Garden
What is valve spring pressure open and closed on ford 600 tractor
this has got every thing but the serviceable spring compression specs on that engine if reconditioning the motor
they focus on getting the right clearance 14 thou inlet 16 thou exhaust
http://www.ntractorclub.com/manuals/tractors/Ford%20Tractor%20Series%20600%20&%20800%20Owner's%20Manual.pdf
Mar 25, 2016 | Ford Naa 600 800 Tractor Tachometer...
2n ford tractor stalls when i let the clutch out
Your clutch needs adjusted a little more. Not releasing all the way.
Dec 28, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
You are framing a rectangular print that is 10 inches wide and 34 inches long. this wall space has an area of 640 square inches. what is the width of the frame so that the framed print fits perfectly in...
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
Feb 16, 2011 | SoftMath Algebrator - Algebra Homework...
Clutch just stopped disengauging. I have been driving this tractor with no troubles for the past month, when depressed the clutch pedel has always disengauged the clutch, but today, I pushed down on...
i have a 8 n ford tractor it want stop when you push the clutch down clutch feel good so i split the tractor and the clutch looks pretty good can you help me
Sep 26, 2009 | Ford Tractor Naa Golden Jubilee Emblem
Garden Logo
41 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
Fahr Quad
Are you a Ford Garden Expert? Answer questions, earn points and help others
