Hello Jeff, for what you describe you have problems in the phono preamplifier stage, it is usually solved by making a replacement of transistors, electrolytic capacitors and some fuse resistors
If you are going to do this work, it would be good if you apply it in all the capacitors and low signal transistors of the equipment
It is very important to get good low noise transistors, just as the capacitors are of the highest quality, to maintain the excellent sound of your Sansui AU-517
Hola Jeff, por lo que describes tienes problemas en la etapa preamplificadora de fono, por lo general se soluciona haciendo un recambio de transistores, capacitores electrol?ticos y unas resistencias fusible
Si vas a hacer este trabajo, seria bueno que lo apliques en todos los capacitores y transistores de baja se?al del equipo
Es muy importante conseguir buenos transistores de bajo ruido, al igual que los capacitores sean de primera calidad, para mantener el excelente sonido de tu Sansui AU-517
SOURCE: wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
SOURCE: Piuoneer DJM600S feedback and cd input problems
Check List :
CD Deck 1 to Channel 1 CD Input
CD Deck 2 to Channel 2 CD Input
Mixer booth output to AMP's AUX or CD input.
use the BOOTH rather than the MASTER
even if you think you've done all these checks, check them again.
trust me I've been a DJ for 15 years & wired up **** loads of systems & still manage to ******* the wiring now & again lol.
you mite need to run an earth from your mixer to your amp.
One more thing, just out of interest you don't happen to have an amp with surround sound do you?
because if you do then switch the effects completely off this should sort it.
e-mail [email protected]
SOURCE: Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Testimonial: "Thanks for your help and time"
SOURCE: how to hookup sansui SE-8
PHONO is ONLY for TURNTABLES. That's why they don't call it AUX.
Wired as I described in the other request, the EQ will have effect of anything that amplifier uses for input once you engage the tape loop the EQ is installed on.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux. eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
