GPS Logo
Question about Buddy GPS
Our Golf Buddy watches no longer charge and last for 18 holes
Jean DeLauche
  • Buddy Master
  • 2,911 Answers
Hello -
Have you considered replacing the rechargeable batteries in the watches?
Rechargeable batteries do not last forever, eventually losing their ability to hold a charge.
Make sure you obtain the right rechargeable batteries for the watches and dispose of the old batteries properly at a location which accepts such batteries for recycling.
Best wishes.
Posted on Jan 30, 2018
1 Related Answer
paul miles
  • 456 Answers
SOURCE: this scooter has not been
hi.
with good batteries, and under ideal conditions (flat smooth surface) this scooter should be good for up to 30 km.
this is highly dependant on the surface, slopes, rider weight, and battery condition, but with good batteries you should easily be able to do a round of golf.
the biggest problem you may have will be the batteries themselves.
after 18 months without use, the batteries may have suffered from a sulphur build up on the lead plates in the battery. this can mean that the batteries will show fully charged, but will not put out the full power. the best way to test this is to take the batteries down to your local car garage and ask them to do a "load test" sometimes called a "drop test" on the batteries. they will usually do this free of charge and it only takes a few minutes. a 100amp load test for 8 seconds should tell you the condition of the batteries.
if the batteries test ok, then you should not have any problems using the scooter for a round of golf.
hope this helps
Posted on Jun 21, 2011
Good day. My Golf Buddy Voice only lasts 9 holes after being fully charged.
Wtx plus works in demo mode but will not work when playing golf on course. Need help.
Nov 23, 2017 • Buddy GPS
My swami 3000 wont hold a charge
stop taking all day to golf,it should last 4 hours if not get a new battery
1helpful
3answers
I have a golf buddy that lose it charge after about 11 holes can I replace the batteries?
I also had the same problem of the battery not lasting a whole round. I found out that if the unit was left for any length of time after it had been fully charged, it would start to discharge even though it was turned off. I now make sure that if I'm playing golf the next day I will put it back on charge overnight.
this has worked successfully for the last 5 months approx
i also looked to find a replacement battery but without success
hope this helps
1helpful
2answers
Golf buddy voice
Not seeing it as a replaceable part - but...if you can take it apart and find a battery for it, why not? Start by taking it apart and taking the battery out, then check the battery for numbers, google those and see what you can find.
Good luck.
Top Buddy GPS Experts
Marvin
Marvin
Tad
Level 1 Expert
Are you a Buddy GPS Expert? Answer questions, earn points and help others
